Painting your own Louvers
Old 07-24-2007, 10:31 AM
banka87
banka87's Avatar
Default Painting your own Louvers
Anyone tried it? I really don't want to pay the extra 100 something dollars to have it prepainted, and I assume it would be similar to go to a body shop.
banka87 is offline
Old 07-24-2007, 12:12 PM
theresa
theresa's Avatar
Default RE: Painting your own Louvers
I had mine painted at dealers and they did a crappy job, lots of runs and contamination. Had to take 'em back and have them re-done. They aren't perfect but better then they were.
Hopefully SOME DAY my husband will put them on.........
theresa is offline
Old 07-24-2007, 12:27 PM
Ken04
Ken04's Avatar
ORIGINAL: banka87
go to a good auto paint store with your paint code. Have the store mix up a couple cans of aerosol paint for you. Prep, prep, prep and then prep some more using a good quality primer/sealer and graduating to a fine, fine wet sand paper of at least 600 grit. The better the surface the less sanding you'll have to do on the actual paint. Spray several light coats, sanding lightly between each coat. After the last coat wet sand, the rubbing compound, then polishing compound to make it shiny and gleaming. Ask the paint store what to use for primer, they know. You can do a good looking job this way. I've done it lots of times.
Ken04 is offline
Old 07-24-2007, 01:46 PM
GrayPony
GrayPony's Avatar
ORIGINAL: Ken04
ORIGINAL: banka87
I don't see a mention of clearcoat in your how to. Without the clearcoat or the proper color primer you won't get a good match.
GrayPony is offline
Old 07-24-2007, 03:15 PM
Ken04
Ken04's Avatar
ORIGINAL: GrayPony
ORIGINAL: Ken04
ORIGINAL: banka87
paint store, best place to get info. They'll know if it's laquer, enamel, acrylic, whatever and be able to get him fixed up with what he needs. I am no painter, I go to the paint store, tell em what I want to do, pay then go do it.
Ken04 is offline
Old 07-24-2007, 06:50 PM
Wickerbill
Wickerbill's Avatar
yeah I would suggest paying a professional to do it. Ive had some body work experience and there are alot of things that go into a good paint job. First you need your base color, catalyst,reducer, and clear. And depending on the material of the louvers the paint shop would first spray it with adhesion promoter first because your paint wontadhere properly without it, the same they use for bumper covers. Then if you plan on buffing them to match the cars paint you would need at least 3 coats of clear. All Im saying is you get alot for that $100 paint job at the paint shop. I would paint them myself but I already have all my materials from painting my bumper cover, if you were to buy the materials to do it like the body shop wouldyou would have $100 already invested
Wickerbill is offline
Old 07-25-2007, 10:36 AM
samuraidad
samuraidad's Avatar
Hey here is another thought if you do not want to pay a shop. Do you have a have vo tech school or a high school with a body shop in the area. Usually they will do it for the cost of parts or in this case thepaint. (the paint can be expensive so check the price at an auto paint store first). If you make a donation you make a friend. they will usually have the senior students do the painting. At our school they actually do some very good work.
[/align]
samuraidad is offline
Old 07-25-2007, 11:10 AM
DUG5SPD
DUG5SPD's Avatar
wait so with the roush louvers can you get them pre painted?
DUG5SPD is offline
Old 07-25-2007, 11:55 AM
GrayPony
GrayPony's Avatar
ORIGINAL: DUG5SPD
Yes you can ... visit the Roush site.
http://store.roushperformance.com/detail.aspx?ID=654
GrayPony is offline
Old 07-25-2007, 01:02 PM
DUG5SPD
DUG5SPD's Avatar
cool thanx!
DUG5SPD is offline
Quick Reply: Painting your own Louvers
