My car is hesitating on me!
This first occurred last week, and I thought it might be a one-off thing but it happened again twice today. Last week I slowed down at a yield that put me on one road from another. I didn't stop, just slowed down at the yield and then stepped on it. I didn't quite floor it, but I gave it a strong push. When I did, the car picked up and then just stalled... hesitated after it picked up and then picked up again. It scared me. I thought I blew the transmission or something before it picked back up. Then today, well, this pretty much happened again in the very same fashion. I was turning from a stop onto aheavy traffic access road and I had to floor it to get out of the way of incoming traffic. Just after I did, it hesitated... a sharp tug back and then it took off as I'd wanted it to about 1 second later. Then it did it again when I turned onto a road on the way home. It seems it only does it when I'm going pretty slow and then try to pick up real quick. Any ideas as to what might be causing this? I never had this problem before in the two years I've had my car.
RE: My car is hesitating on me!
yeah its totally normal especially once you mod the exhaust. the main reason that i have understood is that what goes it must come out. but if you have more coming out than going in then it tries to get that backpressure to give it that umph.
I have an automatic too and used to have a real problem with hesitation. This was pretty much eliminated with a custom tune. A Good tune completely changes the performance of the car.
ORIGINAL: 05madmax
Could a CAI and perhaps a throttle spacer help this problem? I mean, if more air is coming out than going in then how do our carsthat haveduals work?
I had a similar issue with my 05, took it in for a check and I foud out it wouldn't hold fuel pressure, so they replaced the fuel pump under warranty, haven't had a problem since - there is a TSB out on the fuel pump
