gears?
Old Aug 3, 2007 | 04:21 PM
Jsierzega's Avatar
Jsierzega
Default gears?
i know everyone always debates over which gears they should get for there stang, whether its 3.73's or 4.10's. but what happens if you get too high of a gear? wouldnt the acceleration just be harder, and maybe a bit more wheel spin. i have an auto v6 and im not sure on what type to go with.
Old Aug 3, 2007 | 04:39 PM
Nsomnia's Avatar
Nsomnia
Default RE: gears?
There are dozens of thread on this, one near the top of the page. None the less, 3.73's are usually reccomended as best for street driving for added pull while still maintaining low revs while cruising. 4.10s are used to get the best ET at the track usually and are streetable, the revs will jump 1200 or so though.
If you have different sized tires than stock, the ratios will be different and you may have to compensate.
Old Aug 3, 2007 | 04:41 PM
pperin's Avatar
pperin
I ♥ Acer
Default RE: gears?
if you gowith 3.73's you won't go wrong. When you drive conservativly you won't even know they are there but if you get on it.... te car accelarates much better I can spin tires well into 2nd gear. Don't forget to do t-loc as well
Old Aug 3, 2007 | 04:54 PM
mustangman02232's Avatar
mustangman02232
Default RE: gears?
ORIGINAL: Nsomnia
yes, people with absolutely no gear experience will say the same thing
for a DD, 4.10s will be 100% fine, you will loose 2 mpg on the highway
3.73s are good for turbos, or if your trapping 115+, which i doubt your doing
tloks are also hit or miss, some like scrming can be in the 400s for power while yet some can break spider gears with as low as 210 rwft.lbs on DRs
however, if you want it cheaper, mpsautosalvage.com has great used 3.73s for $50
you will need a tuner to correct the speedo, and dont forget a bering kit,
stangmods.com has a tlok
drivetrainspecialists.com has detroit true tracs (stronger LSD)
Old Aug 3, 2007 | 05:49 PM
Jsierzega's Avatar
Jsierzega
Default RE: gears?
when i buy the gears do i get the 7.5 or 8.8 if i get the t-lok aswell
Old Aug 3, 2007 | 07:11 PM
94Blk5.0's Avatar
94Blk5.0
Default RE: gears?
I would go 3.73 with a 7.5 T-Lok.
*Opinion* I would not go any higher than 3.73 for a DD that sees a fair amount of hwy/open road. I am not a fan of high cruising rpms.*End of Opinion*
The 3.73's with a V6 overdrive ratio & stock tire sizeare not going to be that low anyways. 3.73's offer a nice improvment over the 3.31's and raise yourengine speed~200ish-250ish rpms. The 4.10s will do everything more than the 3.73's: higher rpms, improved acceleration.
Old Aug 3, 2007 | 11:43 PM
Wickerbill's Avatar
Wickerbill
Default RE: gears?
I say if ya gonna go gears go all the way and get the 4.10. If you get the 3.73 and your like me you will always wonder what the 4.10 would feel like and eventually get it anyway.
BTW going from 3.73 to 4.10 would be going to a lower gear...gear ratios are bass ackwards
Thunderball
15
Nov 22, 2015 11:49 PM
Bokeo
Oct 10, 2015 08:28 PM
KingRando
Oct 2, 2015 08:06 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
