Idle Problems
Old Aug 5, 2007 | 05:03 PM
2twenty5's Avatar
2twenty5
Default Idle Problems
My Mustang is an '05 V6 completely stock and has been having idle problems recently. When this problem occurs, the idle drops down to 500 RPM and fights to stay running. Usually this happens as I am slowing down at an intersection or coming to a stop, however it is not a consistent problem and seems to happen only once to twice a week. If it dies, it still fights to stay running when I restart, usually causing me to give it some gas to keep it running if I'm at a stop light. I have also noticed that if it can keep running and I put the accelerator down while driving and gun it for a few seconds that it will idle normally the next time I come to a stop.
I have searched forums and found posts by other owners who have had similar problems, but have yet to find anyone who has found a solution to the problem. I know about the TSB about fuel pump problems, but I this seems to be different issue. If anyone has any information or advice it would be greatly appreciated.
Old Aug 5, 2007 | 05:13 PM
Nsomnia's Avatar
Nsomnia
Default RE: Idle Problems
Complete random shot, but check + clean the air filter, perhaps not getting enough air? Or else a vaccume leak maybe.
Old Aug 6, 2007 | 10:50 AM
Wickerbill's Avatar
Wickerbill
Sounds like classic sytems of a stuck EGR valve. Carbon particles can cause the valve to stick open and when you "gun" it the particle is blown through and corrects the problem until another particle gets caught. This happening at least weekly shoud have thrown a trouble code. I dont suppose your check engine light is on is it?
Old Aug 12, 2007 | 05:45 PM
2twenty5's Avatar
2twenty5
Nope, check engine light has never come on. Do trouble codes get logged without the light coming on?
Old Aug 12, 2007 | 06:04 PM
oshkoshbajawsh's Avatar
oshkoshbajawsh
I ♥ Acer
dealer...
Old Aug 12, 2007 | 06:10 PM
Wickerbill's Avatar
Wickerbill
no if it pulls a trouble code your light will definately come on, still could be a sticky egr valve though, I suggest dealer
Old Aug 12, 2007 | 06:11 PM
basketballord's Avatar
basketballord
I had this exact same problem a few weeks ago. I came to the conclusion (after reading this possibility on another post) that it may have been a bad tank of gas or water in the gas because it started acting up right after I fueled up and hasn't happened since I used up that tank. I found this hard to believe, didn't think you could get a "bad" tank of gas. But until it acts funny again, that's what I'm going with.
Old Aug 12, 2007 | 08:34 PM
billybix76's Avatar
billybix76
1) Fuel filter.....2) fuel filter.....3) Probably the Fuel Filter.....And did I mention the Fuel filter?
Old Aug 12, 2007 | 09:22 PM
basketballord
I changed the fuel filter on mine and it still acted up
2007CalSpec
Dec 13, 2020 11:42 AM
2007StangV6
Jan 28, 2016 06:09 PM
96stang3.8
Sep 10, 2015 06:42 AM
94stangnewbe
V6 General Discussion
Sep 7, 2015 07:39 PM
Emblazoned
Sep 3, 2015 10:45 PM
