Dimensions needed
Old Oct 11, 2007 | 08:28 PM
LesteR723's Avatar
LesteR723
Default Dimensions needed
If anyone knows, what is the clearance behind the v6 grille where there is fake honeycomb by the headlights? I want to drill out the fake honeycomb and put a set of fogs behind it, but i need to know wether they will fit or not. Thanks
Old Oct 11, 2007 | 08:30 PM
ODDYSEY's Avatar
ODDYSEY
Site Moderator of Fury!
Default RE: Dimensions needed
I have an extra V6 grill if you want it. I will let it go for a good price.
Old Oct 12, 2007 | 07:14 AM
LesteR723's Avatar
LesteR723
what would be a "good price"? i have seen them going on ebay for under a dollar
Old Oct 12, 2007 | 09:18 AM
157dB's Avatar
157dB
Cut & Paste Expert
No they wont. Aftermarket grills with the fogs have the front of the fogs
well past the front of the grill. Bug eyed, kinda. It would be fruitless to try
as the aftermarket grills that take fogs would look better than some jerry
rigged V6 grill cut out for fogs. Get a tape measurer and go out and measure
for yourself. Been there, done that.
Here is a pic and there is zero clearance behind them. ZERO.
http://img527.imageshack.us/my.php?image=img2763uy6.jpg
Now extra horns, thats the deal. Beep Beep.
[IMG]local://upfiles/69445/05BA7E64370745D6A6B1DE5C69225538.jpg[/IMG]
Old Oct 12, 2007 | 09:45 AM
ODDYSEY's Avatar
ODDYSEY
ORIGINAL: LesteR723
under a dollar with like $50 shipping.
Old Oct 12, 2007 | 10:08 AM
LesteR723's Avatar
LesteR723
ORIGINAL: 157db
thank you thats exatly what i needed to know.
Old Oct 12, 2007 | 10:41 AM
28HopUp's Avatar
28HopUp
MF Administrator
There's not much room back there. Iconsidered removing my driver's side PP foglite so I could run a cold air duct to my CAI. It's just too darn tight behind the grill. You can pull off the plastic radiator cover and see what you have to work with. On those clips, pop up the center part of the clip - once it is up or out you can remove the entire clip. If you try to force out the entire clip without doing that, it'll break.
Have you considered mounting foglights in the lower openings on the bumper?
djbigskrilla
Sep 20, 2022 01:04 AM
Faolan65
Aug 27, 2015 06:40 AM
Faolan65
Arizona Regional Chapter
Aug 25, 2015 09:24 AM
my96mustang
Aug 24, 2015 06:12 AM
defarmer
Aug 13, 2015 06:40 AM
