Surging
Old Oct 19, 2007 | 11:57 AM
erepair's Avatar
erepair
Default Surging
My 05 Mustang 27K miles,has begun surging wildly, when in nutral or clutched , though only occasionally.
Maybe it is when fuel is low. Dealer can't find any problem but tells me not to run gas tank below 1/4 as it overheats fuel pump and this is likely cause of problem
I say its water sucked out by E 10 and as tank gets low it starts passing to engine. Any ideas
Old Oct 19, 2007 | 12:06 PM
erepair's Avatar
erepair
Default RE: Surging
Old Oct 19, 2007 | 12:16 PM
Trmachuno's Avatar
Trmachuno
Default RE: Surging
My dad tells me don't run my car with less than a 1/4 of a tank for that reason. I guess he was telling the truth. That's probably it.
Old Oct 19, 2007 | 12:21 PM
socool9004's Avatar
socool9004
Default RE: Surging
fuel filter, its supposed to be changed every 15k, you guys have double that, you might wanna go pick one up from napa or kragen and change it out, it should fix your problem.
Old Oct 20, 2007 | 11:43 AM
ricekiller06's Avatar
ricekiller06
Default RE: Surging
i take my tank down to the bottom every time to when it says either 5 or 0 till E. i guess thats not good uhh. o well ive yet to surge
Old Oct 20, 2007 | 01:14 PM
Wickerbill's Avatar
Wickerbill
Default RE: Surging
I dont know what to think about the gas tank theory. In my mustang I always try to run the tank pretty empty until I fill it back up on the reasoning that if you leave fuel in it all the time, say 1/4 tank full, that you will get all the nasty things in gas including water settling to the bottom. Many tanks I have pulled on vehicles from around here and you wouldnt beleive whats in the bottom of them. I figure I dont want that in my tank so I always try to run it empty since it was new. My 01 Chevy Blazer is another story. In the past 3 years I have R&R the fuel pump 4 times. Each time with a OEM Delco pump. I always ran the tank empty in it also and after the 2nd pump I was starting to think this wascausing my pump to heatup so I always kept it at 1/2 tank, no change and 2 pumps later I just keep my fingers crossed this one lasts longer. I have putmy meteron it and no current draw, replaced relays thinking I had one sticking, no fix,then replaced the whole in-tank fuel sending assembly this time,I dont know what is wrong with the truck other than it is a Chevy.
Old Oct 21, 2007 | 09:50 PM
laserred02's Avatar
laserred02
Default RE: Surging
running your tank to E will cause premature failure of the fuel pump. the pump overheats and instead of never changing the fuel pump you will be changing it frequently, as well as pulling all the **** that resides in the bottom of your tank into your pump, and consequently your filter.
if you run it low a lot the filter may be your problem.
Diode Dynamics
28
May 26, 2022 12:02 PM
Granatelli Sales
Jan 20, 2020 12:34 AM
MacSerio
Sep 27, 2015 01:05 PM
lmurf60
Sep 24, 2015 10:07 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
