Dynos
Old Oct 25, 2007 | 02:28 PM
Black Mamba GTT's Avatar
Black Mamba GTT
Default Dynos
What is the difference between a mustang dyno and the other kind of dyno, (just forgot what it was called a second ago) and why do they give different numbers. I don't understand. So if I put a 350z on a mustang dyno would the numbers be different on that car as if it where on the other dyno as well?
Old Oct 25, 2007 | 02:38 PM
Trmachuno's Avatar
Trmachuno
Default RE: Dynos
Not sure, but the dyno jet generally dyno's 1.08-1.12 times the mustang dyno's numbers. Different numbers on the 2 dynos but the same amount of power pretty much.
Old Oct 25, 2007 | 02:39 PM
28HopUp's Avatar
28HopUp
MF Administrator
Default RE: Dynos
FIXED
ORIGINAL: Black Mamba GTT
What is the difference between a Mustang Dyno and a DYNO JET, and why do they give different numbers. I don't understand. So if I put a 350z on a Mustang Dyno would the numbers be different on that car as if it where on a Dyno Jet as well?
A car on a Mustang Dyno will produce lower numbers than if it were on a Dyno Jet (with all other atmospheric conditions the same). A rough conversion factor is 7% lower on a MD versus a DJ. Not sure why, but I'm hoping others will chime in.
Old Oct 25, 2007 | 02:50 PM
chavalo_nm1's Avatar
chavalo_nm1
Default RE: Dynos
what about a butt dyno?
Old Oct 25, 2007 | 02:53 PM
Black Mamba GTT
Default RE: Dynos
Yeah I thought it was the Dyno jet just didn't want to sound stupid if I was wrong.
Old Oct 28, 2007 | 08:26 AM
28HopUp's Avatar
28HopUp
MF Administrator
Default RE: Dynos
Here's a good read from a previous thread -
https://mustangforums.com/m_2847645/tm.htm
Old Oct 28, 2007 | 08:56 AM
rygenstormlocke's Avatar
rygenstormlocke
Default RE: Dynos
It depends on the Mustang Dyno and if it is properly calibrated. I have had my car on a DJ twice following it being on the MD at Powerhouse. My car dyno'd 10-12% lower on the PH Mustang Dyno than on a DJ. But it does depend, there is a way to "fudge" the numbers on a MD by entering the wrong parameters for the car.
One thing I will say, the PH Mustang Dyno has predicted my ET's within 2/10ths every time, so I swear by that machine.
Old Oct 28, 2007 | 01:57 PM
chrisc's Avatar
chrisc
Default RE: Dynos
When you do the math/science, the MD reads more accurately. Mustang Dynos are not just for Mustangs, they even make AWD dynos lol!!
It just sucks that everybody runs on the Dyno Jet instead of the Mustang Dyno just because they make "nicer" numbers...
Old Oct 28, 2007 | 03:22 PM
fazm's Avatar
fazm
Default RE: Dynos
dynojets have a standard correction factor. its easier to compare numbers on dynojets from other locations. still not what ud call accurate. but MD can be calibrated differently, so comparing two diff MD's is a joke.
with that being said, a tune done on a MD is probably better.
Old Oct 29, 2007 | 12:45 PM
Sancho805's Avatar
Sancho805
Default RE: Dynos
yeah, i read that MD's are more accurate if done correctly and"truer" when predicting how your car will perform on the street or drag. still, nothing wrong with a DJ.
Galactic
Apr 29, 2019 02:56 PM
articman
Jun 21, 2018 11:45 PM
heslekrants
Sep 23, 2015 04:02 PM
The01Cav
North East
Sep 5, 2015 03:39 PM
The01Cav
Maryland Regional Chapter
Aug 31, 2015 04:12 PM
