tuner quistion ?
RE: tuner quistion ?
ok well it says i have the 87 tune but i thought i was the 93 so i have been using 93 gas, do i just go and install the 93 tune, and also wen i picked the 93 it says that it is for use with the factory airbox?
my old intake was an AEM Brute Force and before i ordered custom tunes, i was running the diablo 91 perf tune. since their is no specific tune for the AEM (i wouldnt think there should be since the MAF housing size is stock), i just used the tune for factory airbox also. i had zero problems. you should be fine if you upload the diablo 93 perf tune since the MMR also uses stock size MAF housing. also, there is NO NEED to revert back to OEM then back to 93.
ernesto-619
09-10-2015 01:32 AM
