Fog light wiring harness
#21
RE: Fog light wiring harness
Hey thanks Tom!! By the way I love the picture of your car in front of that diner with the neon lights. I show my girlfriend that picture all the time...lol Im about to add my 10" gloss black stripes or maybe not because of the cold weather. I've put it off for so long now.
#22
cool just remember to clean the car plenty of times i did it 9 times with naphta to remove all of the old wax before you install the stripes it took longer to clean the car than it did to install the stripes . take your time it took my boy and i all day in the garage. also get a hairdryer and a smal squeege and the soap solution befor you start
#23
ORIGINAL: afixer
as i see it yea you should be able to remove the relay then add the wire to the same position i did. honestly tho the lite is not very bright. and the lights on are more noticable than the little light.
good luck
Tom
good luck
Tom
was not very bright. So before I installed
my GT headlight switch I took it apart and
replaced the OEM LED and resistor with
another brighter LED and proper current
limiting resistor mounting the LED closer
to the front of the switch as close as the
supplied lead length of the LED used would
allow. I also removed the tab that does not
allow you to turn on the fogs without the
clearance lights on.
#24
ORIGINAL: Baadboy11
Holy moses...thanks 157db...is there a specific 30 amp relay i need? and what about fuses?
Also, get a price quote on that OEM GT switch...
Not cheap[8D].
Usually $50 for those pull out fog/head lamp switches.
You'll be at $90 by the time you get all you need.
I could be wrong, but check it out anyway.
Merry Xmas.
