Pypes Exhaust
Pypes Exhaust
Anybody have these? If so got a sound clip and how do you like them?
Item:
SFM68
Description:
05-08 V6 MUSTANG CB W/X SP
Converts V6 cars to True Dual exhaust!. Includes 2.5" mandrel Bent, XFM44 X pipe, mid pipes without crush marks, and a Street Pro Axle Back system. All 409 stainless construction.
Item:
SFM68
Description:
RE: Pypes Exhaust
Here's a link from the forum...scroll down to SOHCman. He has some sound clips. You can also do a search on "Sound Clips" and it will pull up many to choose from.
https://mustangforums.com/m_4072009/tm.htm
RE: Pypes Exhaust
mid pipes without crush marks means its smooth at the bends, as opposed to what i can best describe as a "slinky" look when it bends which is usually what you get at low end shops when they run their own pipes
RE: Pypes Exhaust
ORIGINAL: Fallout
Done with an expensive pipe-bending machine.
RE: Pypes Exhaust
I did a google on mandrel bent tube. Good info. out there
Figure A, the 3" inch pipe that is mandrel bent measures 3" inches at the center of the bend. True 3" inches throughout the pipe will give you 35% less backpressure. Less backpressure equals increased horsepower, torque, and better gas mileage.
Figure B, the 3" inch pipe that is stock bent measures 21/2" inches at the center of the bend. You don't benefit much by having a 3" inch pipe with 21/2 inch restriction in each bend. Your exhaust system is only as good as its weakest link. Why settle for restrictive sub par bending.
Thats the same setup I'am looking at.
RE: Pypes Exhaust
i have that but the violators, i wouldn't recommend going with that, go with something better like the flowmasters, in my opinion the pypes arent deep enough and dont make it sound like i wanted it to
RE: Pypes Exhaust
Depends on what you are looking for as far as sound.
I have that kit, it did indeed sound sweet, but it was far too loud for us. Soundednice inside the car but when my wife left for work in the morning it would wake me up.
I put GT takeoffs on and it's perfect (i.e. quiet at cruise with a small growl when you get on it.)
