VMP MAF Housing
RE: VMP MAF Housing
ORIGINAL: Cabbage
I know it doesn't include the GTA. I never said that I wanted that package with the three. I am going to buy the Ford Racing Borla Muf.
What I am worried about is that I am not getting the full C&L original package with my order.
RE: VMP MAF Housing
Well, yea. For $625.00 that is exactly what you get.
"Package Includes: [ul][*]Custom Programmed SCT X-Cal2 Flasher with up to 3 tunes[*]C&L Full Intake tube with VMP 3" ID MAF housing, S&B Filter, and heat shield
[/ul]
[/ul]
RE: VMP MAF Housing
the heat shield isnt gonna do much. its a thin sheet of plastic that still allows hot air past it. essentially all youre getting is a free-flowing filter and a larger maf housing. unless you can find a way to get external air into the engine bay directed at the intake, youre not getting any difference. the heat shield is simply a selling tool.
RE: VMP MAF Housing
ORIGINAL: 07lane40
RE: VMP MAF Housing
If you are speaking about VMP, his shop is in central Florida so it would be safe to say that some of his dyno runs are made in outside temperatures above 80 degrees, even above 90 degrees.
If you are worried about removing heat from under the hood, which isn't a bad thing to consider with or without a CAI, then go to a shop and ask them to either;
custom fit a couple of grills into the top of your hood to allow heat to escape
purchase an aftermarket hood with vents
a functional scoop will also allow some heat to escape
When it's 85 or above outside and you are sitting at idle, in traffic with the A/C cranking I'm not sure there is much that you can do but venting would be the best
If you think a heat shield on a CAI will yield a tremendous gain; think again. You should buy one with a shield if you like the looks, not for gains. Heck, the metal pipe ones will hold more heat than plastic or rubber ones; that's called heat soak.
RE: VMP MAF Housing
ORIGINAL: torque_is_good
jwog666
12-27-2021 08:09 PM
nmra1965
Other Professional Racing
09-26-2015 10:46 AM
stangin1996gt
09-21-2015 11:01 AM
