Fog Light wiring harness
Can anyone tell me the Ford part number for the foglight/headlight wiring harness? I have the switch, just need the harness. Ford has a grill/foglight kit that comes with the switch, foglights, harness and grill, all I need is the harness. Any help would be greatly appreciated. Wayne
RE: Fog Light wiring harness
Don't buy it from Ford, they will overcharge you.
Try www.blueovalindustries.com they have it for $79.99 which is the average price. If not there, there are plenty of others websites. Even try www.v6mustangstuff.com and they have it too.
ORIGINAL: Lariat
Street Scene sells one thru CaliforniaMustangs for $79
as well as the OEM GT headlight switches or you could
get one off eBay that works with the OEM GT fog light
capable headlight switch.
http://cgi.ebay.com/ebaymotors/05-08...spagenameZWDVW
I have done this and have all the knowledge you need to complete the job.
I did mine with a custom harness I made thats just as good if
not better than the ones available aftermarket.
The FORDgrill kit is basically just an aftermarket type harness
and is nothing like the OEM factory installed fog light harness
wiring. What grill are you installing? GT or Pony type fogs?
[IMG]local://upfiles/69445/61D30598101C4AEEB37BB5F9B66C79AB.jpg[/IMG]
im still trying to figure out my fog situation... i have a gt takeoff grill and need the harness.. my sixxer originally had no fogs and i want to do the pull out switch from the regular light switch... help? either that or id even be ok with tapping into it and having the fogs come on when i turn the lights on... not the parking lights just full headlamps
ORIGINAL: 05nightrider
the OEM fog lamp fuse location with a homemade, autozone available,
fuze tapper. Then I replaced the OEM V6 healight switch with a GT/Pony
headlight switch with the fog light option. The fog light wire from the switch
was then cut and the portion going to the SJB was taped off and the switch
end was extended to under the hood area by the PCM. I also cut the fog
indicator wire and extended this to under the hood by the PCM also.
[IMG]local://upfiles/69445/F8196AF48AFF42B9917E3A7942B8080B.jpg[/IMG]
[IMG]local://upfiles/69445/315109875943426FA4F036C3FFB04139.jpg[/IMG]
The wire from the fog switch was wired to the ground side of the coil
of the 40A lighting relay and 12V to the other side of the coil. The common
of the relay contacts is wired to the same fused 12V for the fogs.
The normally open of the contacts is wired to the fog lamps and the
fog indicator wire from the switch. I also added a high beam relay that
turns on the fog lamps with the high beams if they are not already on.
The mechanical interlock of the GT headlight switch allows for the ding
ding of - you left your lights on, idiot - when you exit the vehicle.
Something the add a non OEM switch kits dont do and the fogs get
left on all the time.
http://iihs.net/fsm/?dir=40&viewfile...0Autolamps.pdf
http://iihs.net/fsm/?dir=40&viewfile...og%20Lamps.pdf
[IMG]local://upfiles/69445/10CB32E251474D2396E999E30A4BA0BE.jpg[/IMG]
I would not recommend that. Been there, tried to do that.
The GT grill is bigger and slightly different how it mounts
than the V6 grill. Get a good aftermarket V6 to GT grill
conversion and save yourself some trouble and heartache.
[IMG]local://upfiles/69445/D4B421314C8F41B9860B6A6F4734F4DB.jpg[/IMG]
[IMG]local://upfiles/69445/63F3B89037CD413E9B9FF2F269347671.jpg[/IMG]
