Flowmaster experience
Old May 3, 2008 | 09:49 PM
red07Pony's Avatar
red07Pony
Default Flowmaster experience
I bought my single axle back Flowmaster AT about8 months ago.I was just under the car to lookinto the squeeking/vibrating noise I've had since I installed it. Well to my dismay it's already rusting!!! [:@][:@] The black paint is pealing and there is rust under there.
Should it be rusting this early???? What are any of you other AT owners experiencing?
Old May 3, 2008 | 09:52 PM
raubt's Avatar
raubt
Default RE: Flowmaster experience
Yep, my single Flow AT was very rusty after a short while.
I'm not sure what the grade of steel is, but sometimes that rust is completely expected and acceptable (sometimes the surface rust even acts as an insulating layer so the more problematic metal-eating rust doesn't show up).
It's probably fine though, wouldn't worry about it.
And even if it does rust through or something in a few years, there's a good excuse for you to slap some new duals on your car.
Old May 3, 2008 | 10:02 PM
Wishbone's Avatar
Wishbone
I noticed Bassani makes an all stainless steel version like the AT for a little bit more.I think I will go that route.
Old May 3, 2008 | 10:05 PM
red07Pony's Avatar
red07Pony
Well the squeeking noise looks like it could be fixed with a few minor spot welds where the muffler connects to the pipe and I was thinking of having somebody do that but now I'm wondering how long this thing is going to last and if it would be worth the welding or not.....
Old May 3, 2008 | 10:11 PM
red07Pony's Avatar
red07Pony
ORIGINAL: Wishbone
I knew this one wouldn't last forever but I certainly didn't expect it to be rusting this soon! If you've heard it andknow that's what you want go stainless steel!!It's money well spent.
Old May 4, 2008 | 08:38 AM
pat6674u's Avatar
pat6674u
I've had my Flows for over 2 tears and there are just a few minor rust spots. I'm assuming you guys live in either really wet areas or that is road salt causing that corrosion.
Old May 4, 2008 | 09:17 AM
Wishbone's Avatar
Wishbone
I found the Bassani axle back for $279 and free shipping. I think I will get it. If you guys want I can post back after I install it and give you a report(or sound clip). I have Bassani on my '01 GT and love it.
Old May 4, 2008 | 10:00 AM
red07Pony's Avatar
red07Pony
Yes Ohio winter = road salt! But still I'm thinking in only about 8 months? Mine will be eaten away in 2 years at this rate. They must not prime before they paint these things. It's too bad because I really like the sound. I'll probably keep it on there till it totally rusts through just to get my money out of it though.
Wishbone - I'm sure somebody has already got sound clips of the Bassani but yours is still welcomed. Variety is good because you may have a better sound quality on your recording than the last guy and help somebodyout. I've heard one in person but unfortunately it was at a car show and we were rightin front ofthe speakers that were blaring music so needless to say it wasn't a great example.
Old May 4, 2008 | 10:05 AM
themac5150's Avatar
themac5150
Yes it will rust, and how quick depends on if the conditions exist to promote it. No way I would weld the AT on the stock mid pipe. The AT clamp is inferior to the stock style band. I remember how much I had to tighten that weird wire thing before it would even snug up. Buy yourself a stainless axle back if you don't want rust. If you want to keep the AT, tighten the heck out of the supplied clamp. If takes a lot more forceto get it tight than the stock method with slits and the band clamp.
Vrooom
Feb 21, 2016 05:25 PM
1996cobraconvertible
SVT Forums
13
Jan 7, 2016 04:50 AM
Ryan Fitzpatrick
Sep 14, 2015 02:21 AM
Sep 8, 2015 11:50 AM
M3hunter
Sep 5, 2015 03:42 PM
