Lower rear end
Old May 16, 2008 | 06:00 PM
Yellow Tang's Avatar
Yellow Tang
Default Lower rear end
I would like to lower it about 1.5 Inches what would be the best way to go? Please list brand of parts recomended and why.
Thanks
Old May 16, 2008 | 06:13 PM
siberian.mist's Avatar
siberian.mist
Default RE: Lower rear end
eibach prokit
adjustable lcas
adjustable panhard
(get pinion, camber angle properly set)
use search youll find a lot more help there is a lot of really good stuff about lowering our cars on here
Old May 16, 2008 | 07:25 PM
jrhykushi's Avatar
jrhykushi
you can pick from eibach, steeda, roush, and frpp (which is eibach).
and dropping only the rear by 1.5 inches would look really unbalanced. if you wanna lower only the rear, go with the roushes
Old May 16, 2008 | 10:00 PM
Yellow Tang
ORIGINAL: siberian.mist
eibach prokit
adjustable lcas
adjustable panhard
Thank You for the help
Old May 16, 2008 | 10:08 PM
Yellow Tang
ORIGINAL: jrhykushi
I was thinking the back only because my car looks like it would be even with the front if it was droped 1.5 inches you think thats a bad idea? I don't want the rear lower then the front but most kits drop the front too and I was thinking the front is fine for me but the rear sets way to high. Also this is my DD so winter in Ohio is the reason I do not want to drop the front any lower.
Old May 17, 2008 | 11:05 AM
outastockjohn's Avatar
outastockjohn
i used the steeda springs, they lowered mine 1 in. in the rear and 3/4in. in the front. looks even all around and its not too low that i cant get around town without problems.
Old May 17, 2008 | 11:15 AM
siberian.mist
just get the roush rear springs. very popular choice. wont lower it 1.5, but will even it out more.
Old May 17, 2008 | 11:26 AM
157dB's Avatar
157dB
Cut & Paste Expert
ORIGINAL: Yellow Tang
ORIGINAL: jrhykushi
The Roush springs will drop the rear 3/4".
Get the matching Roush shocks as well.
It will even out the stance and get rid of
the OEM rake look.
www.mossmustang.com
$125 or so for the rear springs and $175 or so for the matching shocks.
[IMG]local://upfiles/69445/0079414AEAF9447199EDBB692CDE01D1.jpg[/IMG]
[IMG]local://upfiles/69445/96D6F45DE71145129754AAFF4EE624A1.jpg[/IMG]
Old May 17, 2008 | 01:05 PM
Yellow Tang
ORIGINAL: 157db
ORIGINAL: jrhykushi
the OEM rake look.
www.mossmustang.com
Thanks Siberina.mist and 157db This is what I want to do. I like the way your car sets
Old May 17, 2008 | 01:18 PM
dmhines's Avatar
dmhines
I too stuck a set of Roush in the back to level off the car ...
2007CalSpec
Dec 13, 2020 11:42 AM
musnicki
Sep 23, 2015 07:11 AM
Dragonus18
Sep 9, 2015 01:21 AM
Luke9222
Sep 4, 2015 06:46 AM
cbird1177711
Sep 2, 2015 08:51 PM
