right fog emitting brighter light?
Old Jun 28, 2008 | 11:55 AM
machina's Avatar
machina
Default right fog emitting brighter light?
i think my right fog light is a little brighter than my left one for some reason.. any way to fix this?
Old Jun 28, 2008 | 02:01 PM
157dB's Avatar
157dB
Cut & Paste Expert
Default RE: right fog emitting brighter light?
Yes, swap the bulbs and see if the left fog is now a little brighter.
If so replace the dim bulb. They are manufactured to +/- 1% wattage
tolerance so not all bulbs are the same.
If the right fog still seems dim when you switch the bulbs, check
voltage at the light sockets with a DVM to find the cause of the voltage drop.
I see from your sig picthat you have a PP with a GT style grill.
Who did your wiring and how confident are you with their wiring
skills? Twisted and taped connections are a big no-no.
Solder and two stage heat shrink as Ford does is the only way to go.
Old Jun 29, 2008 | 12:38 AM
machina's Avatar
machina
mm.. i actually installed the grille myself and the fogs hooked right up to the factory PP wiring. it was just a matter of plugging out the old PP grille and plugging in the new one.
Old Jun 30, 2008 | 08:58 AM
157dB's Avatar
157dB
Cut & Paste Expert
Mmmmmm
Its a bulb gone bad.
Where did the bulbs that you are using come from?
Ford?
Or cheap aftermarket save every penny bulbs?
Old Jul 1, 2008 | 05:01 AM
machina's Avatar
machina
they came off a GT actually so they're OEM parts
jwog666
Dec 27, 2021 08:09 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Explosive
Oct 2, 2015 07:45 AM
ChampInSD
Oct 2, 2015 04:55 AM
