Adding a LSD
Old Jul 23, 2008 | 02:25 PM
DragonPL's Avatar
DragonPL
Default Adding a LSD
Is it worth it to just add the t-lock and keep the stock 3.31 gears??
Old Jul 23, 2008 | 02:29 PM
shb5007's Avatar
shb5007
Default RE: Adding a LSD
What are you using the car for?
Old Jul 23, 2008 | 02:53 PM
danbevsv6rumbler's Avatar
danbevsv6rumbler
If you're even considering changing out gears in the future, it's worth the wait to do both the t-lok and gear install at the same time. Unless, of course, you have spare cash you don't mind throwing away for labor on a rear-end... twice.
And if that's the case, allow me to help you with some investments
Old Jul 23, 2008 | 03:06 PM
shb5007's Avatar
shb5007
Pretty much what he said.
I just asked because you might not even really need a LSD...
Old Jul 23, 2008 | 04:25 PM
28HopUp's Avatar
28HopUp
MF Administrator
ORIGINAL: DragonPL
For the cost of installing a LSD, you might be able to find a wrecked GT S197 in a local junk yard with a 3.31:1 8.8" rear end (which has a t-lok) and swap it yourself. Ebay will sometimes have them cheap too. Justa thought...
Old Jul 23, 2008 | 07:54 PM
CKurello's Avatar
CKurello
GT's dont have 3.31's (i believe) they only came in 3.55
Old Jul 23, 2008 | 07:57 PM
28HopUp's Avatar
28HopUp
MF Administrator
ORIGINAL: CKurello
All automatic S197 GT's come with the 3.31:1 gearing. All stick-shift S197 GT's in the first few years of production came with the 3.55:1 gearing standard, but then they became an option in 2007 or 2008 (with 3.31's standard). The only exception to this is the S197 Bullitt, which comes from the factory with 3.73:1 gears.
Old Jul 23, 2008 | 08:25 PM
shb5007's Avatar
shb5007
If I could go back I would SERIOUSLY consider just getting an 8.8 rear end...
Why?
- Cost rivals installing t-lok and gears
- I plan to upgrade to a V8 some day
- My rear-end whines
- It will break...just don't know when
The main reason I didn't is weight. I never plan on going FI on the 4.0, but I do want to run 13's NA. Every pound matters to me.
Old Jul 23, 2008 | 08:36 PM
harleystang's Avatar
harleystang
If you're going to open it up, do both at the same time. But, swap in an 8.8 if you can. A bit more weight, but a lot stronger.
Boostaddict
2.3L Eco-Boost Tech
Nov 24, 2015 06:11 AM
Oct 5, 2015 07:40 AM
mungodrums
Sep 28, 2015 10:54 PM
Mr. D
Sep 17, 2015 08:17 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
