applying vinyl rally stripes? can i do this myself?
Like a said, it was not an easy job.. now if you find someone to do them for $120 i'll say don't think about it twice and do it.. you are going to need a hear dryer for the front bumper.
No is not 2" it is 8" but the picture is dark and it can't be seen.
I did mine by myself - no help. It's doable, and the nice thing is, if you by bulk vinyl, you don't need to worry about mistakes. The vinyl I used is 10" wide, and I have a 2" gap between the two (real similar to the original Lemans Stripes on the '65, but those are actually not a constant 10" - they taper.)
My vinyl was a bit expensive (www.vinylstriping.com), but I got the premasked (a must) and also got silver metalic which drove the price up. You get 50 yards for the price, which is enough to do at least three cars. I've done two already, and have more left over. They also supply the application squeegee, a must.
Anyway, some tips:
- As mentioned in an earlier post, clay the entire center of the car before doing anything.
- Soapy water is a must as well. A squirt of Dawn in 8oz bottle is all it takes. This nearly eliminates trapped air bubbles under the vinyl.
- I went to the local autopaint store, and got a 1/2" wide and a 3/4" wide roll of good masking tape.
- I measured the center of each panel, then laid the 1/2" wide right down the center. I put a 3/4" wide on each side to give me the 2" spacing.
- Spray the area generously with soapy water.
- Peal the adhesive off the back, and for large pieces (hood and roof) spray the back with soapy water as well.
- I found that it's best to let it dry for about a half hour before removing the masking from the top of the vinyl.
- The front and rear bumpers I did in two pieces, because of the curvature. Top surface is one piece, then vertical surfaces are another. I overlapped them about 1/8" on the vertical, just below the corner. Hardly noticable.
- Stock front on the V6 is tricky but also doable. For this, I did it dry and also removed the masking before application. Without the masking, the vinyl is quite plyable and can be formed into the curved surfaces.
- The rear faux gas cap is 6" in diameter. I drew a 6" circle on my PC, then drew a line through the diameter, and offset that line by 1" on each side. I printed it out, and then used that for a template to cut the vinyl before applying.
- I also did the rocker stripes myself, with 2" and 1/4" silver vinyl.
That's it - really it's quite easy, you just need to take your time. Doing it yourself is 1/2 the fun of modding IMO.
Anyway, some tips:
