Oil Change
Old Nov 7, 2008 | 09:04 PM
Charlie321's Avatar
Charlie321
Originally Posted by Wishbone
Do what the manual says and change it every 3,000 and have piece of mind. Cost me $10 and 20 minutes to do it and know it's done right. I use Ford synthetic blend and motorcraft filter from Wal Mart.
The manual doesn't say to change it every 3000 miles. It says 7,500. Also, Walmart charges 13 bucks for a five-quart bottle of Motorcraft synthetic blend ($2.97 if purchased by the quart), and another $3.67 for a Motorcraft filter. More than ten bucks, but still a bargain, especially if you don't change it every 3000 miles like some obsessive-compulsive Rainman.
Old Nov 7, 2008 | 09:34 PM
mustangman02232's Avatar
mustangman02232
Originally Posted by davesyo
Maybe I can clarify from what I know about this .You can possibly go longer than 3000 miles between oil changes with regular oil (MAYBE all the way up to the 7500 mile interval ) under IDEAL conditions .However there are too many variables in engine operating conditions .Like for instance, if you do a lot of cold starts and only go a few miles then it is not under ideal conditions or driving where it's dusty or sustained high speed driving .In other words some of the things I mentioned may be normally hard to avoid which means you are operating more under the catagory of severe service and the oil change interval is less.So regular oil change for most people is 3000 -4000 miles but maybe longer under ideal conditions.Store bought synthetics like mobil 1 and amsoil (not castrol syntec ) is every 6000- 7500 or maybe a little more and ester based oil like Redline you can go about 10000 or so.
the easiest way is to just check your oil regularly and when it gets dirty to change it
Old Nov 7, 2008 | 10:27 PM
illin's Avatar
illin
Yeah nobody drives the "ideal conditions" thing to go past 3,000 miles. Do what the manual says and change it every 3,000 and have piece of mind. Cost me $10 and 20 minutes to do it and know it's done right. I use Ford synthetic blend and motorcraft filter from Wal Mart. Changing your oil and filter is the single best thing you can do for your car.
As Charlie pointed out...the manual does not state 3000 miles..it reads 7,500 miles. It also does not state "ideal" it reads "normal".
Most of us (as in 90%) are under normal driving conditions. If we were not, it would be called abnormal.
Old Nov 8, 2008 | 12:29 AM
mustangman02232
actually a majority of people fall under severe driving conditions, i.e. lots of cold starts, several trips of 20 miles or less at a time, etc.
Old Nov 8, 2008 | 01:03 AM
Charlie321's Avatar
Charlie321
Whatever the majority of people do, that by definition, is normal. Still, if you want to err on the side of caution, try changing the oil every 5000 miles. Every 3000 is just marketing.
Show me a person who's pushing the 3000 mile standard, and I'll show you a person who's trying to sell you an oil change.
Old Nov 8, 2008 | 01:30 AM
maxshuty's Avatar
maxshuty
I think I'm just going to do it myself.
What filter should I use and what oil?
Old Nov 8, 2008 | 01:35 AM
pepperquill1's Avatar
pepperquill1
I have mine changed every 5,000 miles
Old Nov 8, 2008 | 03:03 AM
Charlie321's Avatar
Charlie321
You can't go wrong with Mobil One, which is full synthetic but very expensive. Otherwise, the Ford-recommended Motorcraft synthetic blend 5w30, along with a Motorcraft oil filter are both really cheap and really good for the money. I started changing my own oil because I didn't want any minimum-wage chumps touching my car. The money I've saved so far has paid for the Rhino Ramps I use to raise the car.
Old Nov 8, 2008 | 10:46 AM
mustangman02232
M1 is not a real full synthetic
"Whatever the majority of people do, that by definition, is normal. Still, if you want to err on the side of caution, try changing the oil every 5000 miles. Every 3000 is just marketing."
no if you use cheap dino oil and a fram filter you will be lucky to make it the 3k
easiest way is to check your oil weekly, when it gets dirty, change it
Old Nov 8, 2008 | 12:03 PM
Charlie321's Avatar
Charlie321
I meant full, as opposed to synthetic blend.
