sequential tail light problem anyone?
Old Jan 29, 2009 | 11:17 PM
locorider21's Avatar
locorider21
Default sequential tail light problem anyone?
so i ordered the sequential tail light kit from american muscle... i installed in the first time.. they worked great. after two days though. the right side wouldnt sequential on turn signal.. only one chamber would flash..
they replaced them through the warranty.
same thing happend
they replaced them again and same thing happend.
is this happening to anyone else.. could it be my mustang causing the problem?
Old Jan 29, 2009 | 11:59 PM
vtmustangs's Avatar
vtmustangs
Mine have been fine from AM i think I did have to change one bulb one time but I have heard of one wiring harness being bad but happening 3 times seems like either overly bad luck or more likely a problem with your car.
Old Jan 30, 2009 | 08:31 AM
28HopUp's Avatar
28HopUp
MF Administrator
Not to state the obvious, but check your light bulbs (move them around to different positions if need be). My Chasers get all funky when a bulb goes out. If it's the most in-board bulb that's bad, then none of them will sequence on that side.
Old Jan 30, 2009 | 10:24 AM
basketballord's Avatar
basketballord
That has been the one annoyance of my car, the tail light bulbs. I think I've replaced 7 of those things since I've had the car. That's just ridonkulous. Any suggestions for ones that are supposed to last? I was using sylvanias, thought they were supposed to be good.
Old Feb 2, 2009 | 04:30 PM
157dB's Avatar
157dB
Cut & Paste Expert
Another "I got the sequentials from AM and they quit working" post.
Its common.
Buy CDCs and forget about it.
WebLectrics SOX.
Old Feb 4, 2009 | 01:39 PM
rls82959's Avatar
rls82959
Look for a broken solder joint. Tug the wires and one might pop out of the heat shrink tubing or electrical tape. The first set i received was soldered poorly. Insulation melted and solder flowed under the insulation, making for a brittle solder joint.
EDIT: BTW, mine are CDC's
Old Feb 4, 2009 | 04:44 PM
drfister's Avatar
drfister
+1 for CDC sequentials.
...Sadly, I have the Webelectrics from AM too. Had to replace a bulb the other day for the first time. I hope this is not going to be a continual problem. There have been many that have had issues with the harness' and many who have been problem free. Luck of the draw I suppose.
Old Feb 5, 2009 | 08:58 AM
157dB's Avatar
157dB
Cut & Paste Expert
The WebLectrics 'slap' the bulb filiment with 12V
everytime they flash.
The CDCs have a soft start feature that brings
the bulb filiment up to 12V at a predetermined
ramp up rate undetectable to the naked eye
but easily seen on an O Scope.
I also replaced ALL the taillight bulbs with LongLife Sylvanias FTW.
Old Feb 5, 2009 | 11:54 AM
oh6vee6's Avatar
oh6vee6
I put mine in about a month ago and changed all the bulbs to Sylvania Long Lifes and they have been fine. Figured I didn't want to take the car apart more often than I have to. Keepin' my fingers crossed now though.
JonnyBlazeGT
Nov 3, 2015 01:10 AM
kdryan
Aug 21, 2015 04:01 PM
jjwinel78
Aug 17, 2015 03:34 PM
chain
Aug 17, 2015 08:52 AM
philster0306
Aug 10, 2015 11:33 AM
