BBK 70mm Throttle Body
Bigger injectors won't give you more power. Your car isn't tuned to take advantage of those injectors, so you won't be making any more power from those. And as far as the TB spacer, they've been proven not to be worth any gains. I think you are experiencing a placebo effect, so to speak.
I'm not trying to bust your stones, I just don't want people seeing something like this and thinking Oh so if I go spend 70 on a spacer and $XX on bigger injectors i will gain 10-20 hp/tq. They will be sorely disappointed. There is no need to get hostile.
As far as a throttle body goes it will give you better throttle response yes but without a custom tune the preloaded fuel map on any tuner will not take advantage of the extra air it can pull so to speak so you will not see any gains unless you are charged(F/I) in some way.
As far as your injectors go, The fuel map for a canned tune doesn't change when you tell the device you have bigger injectors it just helps the computer know that it doesn't have to run the injectors quite as hard. Injectors are another item you have to be custom tuned for or they are pointless. On a full bolt-on 4.0L mustang the stock injectors are big enough to cover the load. You won't need or be able to make much use of bigger injectors unless you are going with a turbo or supercharger pushing a decent amount of boost.
If you are using a can tune from your diablosport tuner then you can take everything else back to stock and you will still have just as much power because the increased hp & tq are all from the tune. If you are using a custom tune then you might be getting a little more hp than you would without those items but were talking 1-3hp at the most (none from the spacer I promise)
Dude...you can take that attitude to some other forum. No need for it around here.
You received solid advice and like those already posted...you are NOT getting 10 or even 5...or even 2 hp from bigger injectors. Couple that with your TB and a stock car will likly out dyno your car. Not what you may want to hear, but it is the truth.
The S197's have been out for enough time that countless folks have experimented with every conceavable go-fast part. Neither of yours are on the list as they yield no gain.
Look through the 1/4 times of the fast 4.0's and you will see a trend.
For $2k, you can your car below 14.5 (mine is a perfect example). Gears, tlok, a good and aggressive custom tune, a CAI and better flowing exhaust and you have a ride that will be very close to previous gen GT's and beat SN95s (stock).
After that...it gets expensive. You want to get into the 13's...you can spray. However, to really make the jump, you need to go FI.
So, read and evaluate what others here have experienced. Dont like it? Fine...but keep the attitude to yourself. If you cannot handle that...take a hike.
bigger injectors will add ZERO power without more air, and in stock form the 4.0 cant even flow enough air to max out the stock injectors (not even close).
all they will do for you is decrease your gas mileage, and probably lose power (richer = less power)
