Questions about Zex Kit
I read the Nitrous intro in the Pipes, Boost & Juice section but I'm still a little confused. After an aluminum driveshaft I think N20 will be my next upgrade, definately a great alternative to F/I, so I wanna learn as much as possible.
1. "75" shot or "100" shot pertains to the boost of horsepower?
2. When does nitrous spray? All I know about it is what you see on Fast & Furious where they push the magic button for NOS lol. Do you set it to only spray at WOT and have an on and off switch for DD use?
3. How safe is it on your engine? I'm assuming it's safer than FI as your engine is only under increased stress while your spraying at the track as opposed to almost always with boost?
4. How long does a bottle last? Is there a certain amount of sprays or do spray lengths vary?
5. How much to fill up a bottle?
I've always wondering this about N20. Please Help
I can hit most of those.
1. Yes. I am going with a 100 shot.
2. All the kits I am looking at have an "electronic" wide open switch...so they come on when your pedal hits the floor pan. One big benefit of drive by wire I guess.
3. Very with a solid tune...but the same can be said for FI too. These are STRONG motors.
4. There is a formula to figure it out based upon your jet size, but there are all kinds of other factors. I havent ran N2O in a lonf time, but we got about 90-120 seconds on small jest (75 or 100) on a 10# bottle. You are looking at 8 good runs on a bottle.
5. $4-5 a pound at the track, less at your shop...around $3.50 at my local shop.
I just have to decide which kit to go with. I am leaning towards the dynotunes kit as it seems pretty complete. I too am doing this right after the al driveshaft.
Then I am done.
Really.
Then I am done.
Really.
^^^^^^^^^^i don't think so...i was done after my intake and exhaust...lol
i am probably going to get the Dynotunes kit just so i can buy more accesories like a bottle warmer and blowdown kit.....maybe the purge kit to get more consistant runs....i am only going to be using this at my local drag strip, so i am gonna need to swap tunes when i wanna install the bottle..BTW the Speed of sound cup holder switch will definatly find its way into my car when i get this stuff.....probably gonna order all the goodies in a week or two...when i get my taxes back
Then I am done.
Really.
Then I am done.
Really.
1. the # represents H.P. but you'll also get a big boost in torque. Higher than the HP # at low rpm and typically drops below at the upper range.
2. Only @ WOT above 3k for ideal safety (i sprayed @ 2800 until my clutch started slipping). A master power switch arms the whole system. a more advanced set up uses a window switch to provide added control. it will only activate the solenoids in the user specified rpm range and beginning gear, so all you need to do is drive.
3. for added insurance use a window switch and at least a Fuel Pressure Safety SwitchT'd into the fuel rail that will deactivate the system should fuel pressure drop below 35 psi. just like f/i lean = breakage.
4. I get 7 strong passes on the 100 shot and can squeeze 10 passes out with at least 15-20 min between rounds to heat the bottle back up to pressure. by the 10th I can't hold full pressure for the full run. Oh, and a quick purge up to the 7th pass.
5. I pay $3.75 lb. Try this refill locator for some shops near you.
I had a zex kit, before the S/C. You have to have that Kit tuned like crazy. I had 150 shot on stock motor and ran mid 12's, it was a stick car so i was snatching gears. But i really like the kit. I really like it cause you can set it up to spray off the line while tuning it to the ecu. The best thing to do with the zex kit is setup 2 stages. Its really cheap and easy to do!
