2006 TCS/ABS lites on
Just a quick question I have a problem on a 2006 mustang v-6 (wifes car). ABS and TCS warning lites on. Read codes c1165 (speed wheel sensor RR input circuit failure) and c1235 (speed wheel RR input signal missing) . Based on this I replaced the RR sensor but lites still on. Question is, does anything need to be reset or does system check on startup automaticaly reset itself? I assume it may be a fault in the wiring at this point. Also has anyone used the ALLDATA web site where you purchase a 1 yr. subscription to the repair manual for your car on line. It's suppposed to have all the dealer and tech info you need including wiring diagrams. Thanx for your time.
George
George
BeatnikFink
10-01-2015 08:00 PM
09-17-2015 07:57 PM
