Pony Package install-white/yellow wire?
So as I'm reading over my instructions for the installation of a pony package grill, I've come to a snag in the process. Tried searching but there was no help to be found.
It says I'm supposed to splice the yellow wire in the foglight harness with the yellow/white wire that runs from the fuse box. I looked under the hood, and there's no yellow/white wire. There's a yellow and green wire, and a red and white wire, but no yellow and white wire.
My car is a 2005, so has anyone out there run into this problem? Which wire do I splice?
Which fuse box?
There are two fuse boxes in the S197.
Without having made the harness that you
are using and since wire colors are not standardized
between manufacturer, its hard to tell you what to
hook the yellow fog light harness wire to.
Tell me what the yellow wire does
and I will tell you just where to hook it to in your 05...
http://iihs.net/fsm/?dir=40&viewfile...0Autolamps.pdf
I'm pretty sure it should have a yellow/white. When i put in my projectors i rember seeingit bc it make me thing of a banana and then i drifted off thinking about throwing rotten bananas at bad drivers as i passed them. Not joking. So ya it should b around there some where.
The Yellow and white is for the High Beam cut out relay , the lights will work with out being hook up , I too did not have a Yellow and White wire in the Harness , Just turn on your high beams and find or follow it over to the headlight High Beams ,, hook it on that wire , I think it is the white and green wire ,,BUT check , ,,When you turn on your high beams the fogs are suppose to turn off , I left mine so it will stay on all the time
mungodrums
09-29-2015 09:18 PM
jaiidutch
09-14-2015 10:29 AM
