Adding midpipe resonators? What length?
Hi guys..
I have had my duals with Pypes Violator mufflers on my car for a few weeks, and although they sounds awesome around town and at WOT, the setup gives me a drone headache on the highway. I drive about 70 miles each day at steady highway speeds of 75-80 or so. My question is... I want to keep my Violators, but cut down on the drone as much as possible on the highway. I do not want to try Dynamat, since my trunk is already well insulated. Now, how about adding mid pipe resonators into the mix??? Two, straight glasspacks maybe? I could get some Cherrybombs, or Dynamax and have them put in the middle of the mids. But, what length should they be? I found 8" and 18" in 2.5 OD. If I have them put in, should I have them staggered in position, so that the drone will be reduced? If I put them in the same spot on both mids, then the mufflers would be generating the same drone/frequency sound out both mufflers at the same time. I think that I'd want to avoid that, right? What would you guys suggest. My thought is that two small glasspacks in the mids, would mellow down the Violators a bit, and cut out the darn highway drone at 1700-2300 rpm range. Suggestions welcome.....
well, it sounds like you have the right plan. I have borla stingers and they drone on the highway as well, and i am looking into the same set up as you. Im interested in how it turns out for you, I will be doing the same in a month or so. Most muffler shops have a stock of midpipes and if you go to a reputable place they should know what to do...
I had the same drone issues with flowmaster 40 series on my car. Installed two 18" magnaflow round resonators on the midpipe and it didn't do anything...
I ended up taking off the flowmasters and just running with the 18" magnaflows midpipes only and they have been on my car since
ZERO drone
ZERO drone
Oct 5, 2015 07:40 AM
mungodrums
Sep 28, 2015 10:54 PM
junior04
Sep 28, 2015 10:53 AM
Daddys Girls GTs
Sep 14, 2015 08:46 PM
