Two prolems :( Whistling noise, turning noise
When I put the peddle to the metal I hear a faint whistling noise, anyone know what this could be?
Also when I'm at a dead stop and I accelerate while turning left/right I can hear a rattle for a second then it goes away as the rpm gets a little higher. I never noticed this until a couple days ago when it was nice out I had my windows down and the music off and I could hear it. It's only at low RPM's and while turning (it's not tire rubbing). It's just a small rattle noise.
Anyone know what these could be??
I've only got 1,000 miles left on my warranty and I've gotta get these things fixed! I've got a few other things that still need addressing too.............
-Drivers side and passenger side door there is a constant rattle in the door hinge. I already had the dealer fix this once and they came back way worse then before
-Using a lot of antifreeze
Help
Help
Do you have a CAI? If so that would be the air being sucked into through the throttle body.
Could be exhaust or a 100 other things. Rattles can be tough to pinpoint.
Help
Help
It must be a leak because I dont seem to have any of the other symptoms. That is covered under warranty right?
And no my engine is stock, no CAI or anything...... I thought it might be a bad belt or something... it doesn't sound good though..... to me it almost sounds like my old bonneville's supercharger whine.
The Rattle doesn't sound like its from the exhaust, but I'll try and pinpoint it better with someone else driving and me outside
09-27-2015 03:16 PM
logan409
09-26-2015 07:43 PM
