door panels
1. Remove the sail panel.
*If equipped, disconnect the exterior mirror control switch electrical connector.
2. Remove the interior door handle cover and the door trim panel bolt.
3. Remove the window control switch housing.
*Disconnect the electrical connector.
4. Remove the door trim panel center screw.
5. Remove the door trim panel handle cover and the door trim panel bolt.
6. Remove the 8 outer door trim panel screws and the door trim panel.
*Disconnect the interior door handle actuating cable.
*If equipped, disconnect the subwoofer electrical connector.
7. To install, reverse the removal procedure.
1. 17D698 RH/ 17D699 LH sail panel
2. 21999 Door lock control **** bezel (RH/LH)
3. 22620 RH/ 22621 LH Interior door handle cover
4. N807780 Door trim panel bolt
5. 14527 RH/ 14528 LH Window control switch housing
6. Window control switch electrical connector
7. W709996 Door trim panel screw
8. 6320456 RH/ 6320457 LH Door trim panel handle cover
9. N807780 Door trim panel bolt
10. W709996 Door trim panel screw (8 required)
11. 23942 RH/ 23943 LH Door trim panel
part#'s are for reference only (not the actual part #)
