Rear Sway Bar Hardware
Old Jan 29, 2010 | 05:24 AM
  #21
akdoggie's Avatar
akdoggie
Smile actual sizes
I didn't see anyone list the actual sizes for the rear bar bolts and nuts so here they are.
lower mounts
4 ea 8mm x 20mm bolts
4 ea 8mm flat washers
4 ea 8mm lock washers
4 ea 8mm lock nuts
upper mounts
2 ea 12mm x 70 bolts
2 ea 12mm flat washers
2 ea 12mm lock washers
2 ea 12mm lock nuts
Grade 10.9 is recommended.
I hope this helps. The Ford numbers mean little to most people when it comes to standardized hardware. This was a 10-15 minute simple install. It took longer to find the loctite than the job itself. Yes, I use loctite with metal locknuts in critical stress areas.
Old Jan 29, 2010 | 10:00 AM
  #22
rockon1's Avatar
rockon1
Originally Posted by So_Cali
Steeda actually sells a hardware kit but, its only for the rear.
Found Here
This is where I got mine, worked great and only 15.00
Old Feb 1, 2010 | 04:46 PM
  #23
157dB's Avatar
157dB
Cut & Paste Expert
Grade 10.9 is way too brittle for suspension fastners....
So is grade 8.
Old Feb 1, 2010 | 06:01 PM
  #24
MoneyShot's Avatar
MoneyShot
http://www.boltdepot.com/fastener-in...Materials.aspx
"Determining Bolt Grade
Bolts of different grades are marked on the head to show what grade bolt they are. For a list of the most common grade markings see our Material Grade Identification and Properties Chart.
Grade 2
Grade 2 is a standard hardware grade steel. This is the most common grade of steel fastener and is the least expensive. Grade 2 bolts have no head marking (sometimes a manufacturer mark is present).
Grade 5
Grade 5 bolts are hardened to increase strength and are the most common bolts found in automotive applications. Grade 5 bolts have 3 evenly spaced radial lines on the head.
Grade 8
Grade 8 bolts have been hardened more than grade 5 bolts. Thus they are stronger and are used in demanding applications such as automotive suspensions. Grade 8 bolts have 6 evenly spaced radial lines on the head."
http://www.boltdepot.com/fastener-in...ade-Chart.aspx
Class 10.9 Metric >= Grade 8 US
http://iihs.net/fsm/?dir=65&viewfile...izer%20Bar.pdf
W708737 = M12 x 1.75 x 65mm
W711368 = M10 x 1.5 x 30mm
per Ford Parts Dept.
Old Feb 2, 2010 | 10:36 AM
  #25
157dB's Avatar
157dB
Cut & Paste Expert
Just ask someone whom mounted their winch
with grade 8s and see how that worked out
for them when it was needed the most....
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
Gene K
Oct 21, 2015 11:37 PM
Sep 16, 2015 07:53 PM
fastbackford351
Sep 12, 2015 09:42 AM
robjh22
Suspension
Sep 8, 2015 12:47 PM
