limiter?
Doug does remove the limiter... however........
The limiter is set to 113 and I wouldn't go that fast unless at the track.
I wouldn't even think about going that fast with out a different driveshaft and better suspension anyway.
yeah i thought doug did, nah actually i found this out at the drag strip, i was there just to see what the car had and it got up too 113 i guess , really quick and that was it i as like damn lol...what can i our cars go up to when tune "stock tho" ?
Only 05 and early 06 V6s have the "bad" driveshaft. No u-joint clips. There is no problem with late 06 and up driveshafts, its just very heavy compared to an aluminum one. 30 lbs stock to about 17 lbs on the aluminum one. The reason the car has a speed limiter is the stock BFG 215x65x16 tires. There only(T)rated to 112 mph. If you have a tuner you should be able to turn it off very easily. When you first plug in the tuner you will get a message that asks if you want to change any parameters, push yes and you will get a list of thing you can change or adjust.
JoshyGT
09-19-2017 08:52 PM
treesloth
09-28-2015 07:03 AM
uberstang1
09-20-2015 06:42 PM
