someone help!!! lowering car!!!
Old Jan 15, 2010 | 10:30 PM
  #51
08blackoutstang's Avatar
08blackoutstang
o and also you guys where talking about "toe" when i get my car professionally aligned will they know how to correct this?
Old Jan 15, 2010 | 11:19 PM
  #52
2010V6Stang's Avatar
2010V6Stang
BEWARE! Possible Scammer
Yes it will corrected during a four wheel alignment.
Old Jan 16, 2010 | 08:51 AM
  #53
ODDYSEY's Avatar
ODDYSEY
Site Moderator of Fury!
Originally Posted by 08blackoutstang
hey i know i am probibly beating a dead horse but are you guys also saying i need new shocks and struts? If i am paying 300 to have this done now, then i might as well have them put the new shocks and struts in to while they are at it, so i can avoide onother charge in the future when i have to put them in,
so in short do i need new shocks and struts with a 1.5 and 1.75 inch drop?
You don't "need" new shocks and struts now, but it will save you money in the long run to have them put on now. Your stock shocks and struts will wear out faster when you lower your car, after 3 months mine were noticablely bouncy and that is when I changed mine out.
However, I did everything myself, so if you are going to pay someone, I would save some money and get it all done at once.
Old Jan 16, 2010 | 09:19 AM
  #54
157dB's Avatar
157dB
Cut & Paste Expert
If you do the bump steer kit, your toe wont be out enough to matter.
Just think of it as keeping the geometry the same on your tie rods the
same as it was before it was 'lowered' with springs.
I say go dropped spindles and still retain the full OEM front suspension
geometry for about the same price as all the lowering springs, struts,
bump steer kits, X5 ball joints etc.
Dropped spindles is the only true 'right' way to lower the front end
of a S197 05-09 Mustang.
Old Jan 16, 2010 | 12:32 PM
  #55
08blackoutstang
ive already bought everything but the shocks/struts so.... stuck with what i got
Old Jan 16, 2010 | 12:34 PM
  #56
08blackoutstang
you have a spring compressor?
Old Jan 16, 2010 | 01:50 PM
  #57
157dB's Avatar
157dB
Cut & Paste Expert
OEMs require the compressor to be safe but they come apart without one.
The new ones are shorter and can be installed without compressing them...
Old Jan 20, 2010 | 09:34 AM
  #58
replica's Avatar
replica
I just got my car aligned last night. As a refresher, I installed the FRPP K-Springs last week and I've been driving on them for about a week to make sure they settle. I've done nothing else but put the springs on. The alignment was $109 for a 1 year term at NTB.
My toe was completely thrown on both sides of the car. The camber was -1.4 on the driver's side and -1.7 on the passenger's side. The toe was corrected during the alignment. The camber was not. Rides great! I can go a good 20 seconds on the freeway with my hands off the steering wheel and I'll still be in my lane. The car has some nice "bite" at turn-in now. Perhaps that little bit of negative camber helps with that. The -1.4 was in the "green" so I assume that was tolerable in and in spec. The -1.7 was slightly out of spec.
So fear not. Installing just springs will not make your car explode.
Most auto parts stores will rent a compressor to you for about $50. It's just a giant clamp that uses a large socket (usually a 19 or 20) to compress the spring as you ratchet it down. Really simple, but rather boring.
Old Jan 20, 2010 | 09:47 AM
  #59
ODDYSEY's Avatar
ODDYSEY
Autozone rents them for free. $50 deposit, but you get it back when you return it.
Old Jan 20, 2010 | 01:29 PM
  #60
08blackoutstang
THANK YOU SO MUCH
inyadreems
Aug 21, 2015 09:10 AM
chain
Aug 17, 2015 08:52 AM
92 5.0stang
Aug 13, 2015 06:46 AM
Milan Dragway
Aug 12, 2015 03:43 PM
ccwebb
Aug 11, 2015 06:47 PM
