Enhancing water meth system.
There's part of the difference, I'm getting 300 to the wheels (ok, 299.8rwhp on the last run)
What I'm running:
X-Charger w/ 2.8" pulley and Wet-X
FR intake w/ custom tube
Screamin' Demon coil w/ MSD wires
NGK TR6 plugs gapped at .044 and indexed
Duals w/ JBA shorty headers and Corsa RSC mufflers
3.5" Aluminum driveshaft and SPEC aluminum flywheel
Royal Purple fluids throughout (Engine/Tranny/Diff)
What I'm running:
SCAM ALERT! This person is known around the internet for ripping people off. You've been warned.
I don't know why you are getting more than me, other than the coil, flywheel and driveshaft I'm pretty much the same. Do you have results prior to certain mods, so you can discern where the biggest gain was at? I'm thinking the coil and the flywheel. And did you index on your own?
I don't really have a sequence of dyno results like you're asking for, I don't get it dyno'd every time I make a change.
Yes, I did the plug indexing on my own. It's sort of tedious, but not difficult.
I got it done on a dynojet 3 pulls. The only problem I could see(I honestly forgot about this) is that my peak boost is about 7lbs. I'm guessing it is because my rotors are scored a little.
If you're running a 2.8", you're right, that's low. Belt slippage might be a possible cause too.
But my curves were pretty smooth, so i figured no slippage. I wanted to go to a smaller pulley to make up for the blower inefficiency.
