GT strut tower vs. V6
I used the frrp gt strut brace on my v6 couldnt pass up the deal on it and at the time didnt know it would not fit without mods. just trimming the web on the intake a little and spaced the mounting points up a little and it all clears. its just the front bar that hits back has lots of room.
Its basically an appearance item at best.
I may try one again someday, if the opportunity presents itself. I did not have a good experience with the one that I have had in the past....lots of vibration transferred thru the car with it on. I suspect that it was contacting the plenum with torque on the engine.
Both camps have there opinions of the STB. Thats what nice about this country!
Ouch!....guess I should have chosen my verbiage a bit more carefully. And, on both points, your correct.....I don't have one (anymore), and I don't "throw" my vehicles thru turns or anywhere else for that matter....I quit doing that about 20 years ago.
If you were getting vibration with the STB on, I suspect you're right, it probably was making contact with the engine somewhere.
This is the one I run and YES, it does make a difference in handling. This will work for ALL 05-09 mustangs (with and without a plenum cover (which I have)) although the hood liner may give some interference prior to a 2007 build. The 07+ hood liner has some notches in it to accomodate a factory strut tower brace. Prior to 07 you may have to cut the liner or deal with the rubbing.
http://northamericantuning.com/catal...roducts_id/994
The coupes are stiff enough for me (thats what she said).
I would get a G-Trac brace before a STB anyday...
Some S197s are actually MISSING this part from the factory...
Crawl under and have a look see ifen yous gots ones.
I do agree 100% on a G-Trac/K-Member race. Very worthwhile to add. The 'verts all come with them as far as I know, but even that can be beefed up with a better one with more/better anchor points like the CHE piece.
Edelbrock makes a brace that also attaches to the firewall. The catalog says it does not fit convertibles. Does anyone know what difference would be between the coupes and
convertibles that work prevent it from working on a convertible?
