Big Job ahead, 8.8 Axle & suspension
UCA Bolt 124 ft lbs.
LCA Bolt 129 ft lbs
Lower Shock Bolts 124lbs
Shock bolts in the trunk I could not find a spec so I just did them as tight as I could before they started spinning, then did 2 full turns with a 2nd wrench opposite pressure.
Driveshaft to Pinion adaptor 41lbs
LCA Bolt 129 ft lbs
Your the man! Thanks Dude.
Boostaddict
2.3L Eco-Boost Tech
Nov 24, 2015 06:11 AM
Sep 24, 2015 09:18 PM
Sep 10, 2015 08:39 PM
Sep 8, 2015 11:50 AM
