Stop bump or catch up bump
This just started occurring a few weeks ago. When coming to a stop the car stops then there's a bump. Almost feels like the rear end is draggin behind then catches up to the stopped car and bumps it. Haven't had a chance to get under it and check for anything loose. Wondering if anyone else is experiencing this.
To be clear - there are TWO bowling ***** in the trunk, no kidding. When I asked her if she had noticed it, she told me the same thing.
Plan to get under there soon to check bushings and such. I did have the LCAs off to regrease them, but that was a sometime in December.
You could just be getting the slop from the mis matched bolt and holes in the UCA. I used to get that same bump feeling, but not so much now that I upgraded the UCA and HotPart included the step part to fill the hole up.
Can you put the right size bolt in the hole to stop the bump? I haven't experienced it yet, but was just wondering if that was a quick fix.
I don't think you can change the bolt - you need to change the stepped spacer in the mount. The hole in the UCA won't take a bigger bolt. You can order just the spacer I believe - but if you are going to have to take it apart anyway might as well consider the upgraded UCA. When I got mine from Hot Part they included the stepped spacer.
mungodrums
Suspension
09-24-2015 10:12 PM
