Check Engine light ON after installing BBK CAI...
Well, I've just installed my very first mod to my 2010 v6. I thought it went perfectly, and while I was enjoying my new torque (albeit without a tune yet, BBK claims this one doesn't need one- though it is planned), the check engine light has popped on...
The only thing I can think of that might be the culptrit... is I have a lot of types of gas in my car right now. That is - I had a half tank of Regular, and in anticipation of installing the CAI (BBK had a notice about check engine light if the engine runs too lean due to the added air) I topped that up with Premium 87 and 93 octane stuff. So there's a mix of fuel that maybe isn't jiving with the engine?
I guess my main question is, assuming I installed that thing correctly (and I'm 99% I got it right)- should I really be worried about my engine's safety? If it's due to my fuel mix, could it turn off as I fill it consistently with one rating of higher octane fuel?
Did you remove the negative battery cable from the battery for a few minutes after installing the CAI? That sometimes helps with the "no tune required" sort because it forces the computer to go back to it's baseline setting and "re-learn" the self adjusting engine management parameters. Worth a try anyway.
Arrgh! I left the negative connector unplugged for about 20 minutes- then just went to connect it again...
when I touched the connector to the battery I saw sparks! And the lights flashed on for a sec... the car is most definitely off and the lights are off as well. What's the deal?
I was able to disconnect/reconnect the negative plug no problem earlier today...
Haha.. okay. Whew! This hobby is... exciting. Okay so the sparks went away after I just hauled that cable up and planted it on the battery. Car started up, check engine light gone.
So I called it a night.. hopefullyI won't see it again when I go in to work. I think if I just lay off the peddle a bit... while the computer adjust. I don't know. When I really slammed it on when gunning past some other noisy sports car with my new juice - that's what set the light off.
05Mustang, you have experience with BBK I see. So you think that now the light is cleared I probably won't see it again?
I certainly don't want my engine running 'lean', I assume that's bad. It's just a matter of using the better fuel I assume.
I highly recommend purchasing a tuner with 3 custom tunes from Brenspeed or American Muscle. This will eliminate the error issue and also add real HP/Torque!
I purchased the Airaid CAI, which also does not require a tune. Fortunately, I did not have any code issues, however, I only felt minimal HP/Torque gain. Maybe a 5 HP or something.
I went with Brenspeed and am VERY satisfied with the HP/Torque performance, especially around the 2,500 - 2,800 RPM rang!!
The tune really wakes up the Stang and is more enjoyable to drive.
