Well, I really messed this one up. Need some help.
So I was putting on my C&L CAI today. I followed the instructions on American Muscle exactly.
The problem is, I got distracted while putting the MAF sensor in the new housing and started to screw it in with the old screws! I got 1 screw almost in (it wasn't easy, but it wasn't too hard at first) before I realized what I was doing. It started to get kind of hard to turn, so I stopped, noticed the little baggy with the right screws, and understood what I had done.and slowly, carefully, tried to unscrew it, but it wouldn't budge. I applied a little pressure and the head snapped right off! It was almost flush, so I couldn't grip it with anything. I had this little screw extractor thing, so I went to try it. I drilled the hole and then went to use the extractor, but the extractor wouldn't grip the screw no matter what I did. I called up some people I know who are good with it and they suggested drilling the whole thing out and re-tapping it, but I am not about to do that.
Does anyone know anything that can help? I have to go to my first day at my first job tomorrow and don't know if I can find another ride.
Is there any chance you can get to even just a small portion with a pair of vice grips? My only other suggestion is to drill it out with a bit just a tad smaller than the threads to see if you can save them.
If the old screw is in securely, you might just want to continue the install. As long as you have an air-tight seal, it should be fine.
well if its the aluminum CL intake, then the best thing to do would be to re-tap the hole and us a stainless steel screw to match the new threads. Its not that hard to do, and patience is a virtue with re-tapping anything, never use a drill use the re-tap handle set. Irwin is the brand i use for my re-tapping needs.
Thanks guys. I used some seriously high grade servo tape (thin, double sided foam tape) around the edges of the MAF sensor and then screwed the 1 correct screw in. It seems to be airtight, but we will see. I hope to get the hole re-tapped and all soon.
Thanks for the help!
breaking
10-02-2015 01:27 PM
KingRando
10-02-2015 08:06 AM
