Definitive tire size questions
Old 03-18-2011, 08:36 PM
swagfu
swagfu's Avatar
Default Definitive tire size questions
Looking at getting some new rims an tires.
Can someone tell me what the largest size 18" tire i can get would be. I like a little meat on the rim and if I could, I would go to a 16 inch wheel with a larger side wall. I have 17" now and may end up going with that.
I need to know the tire height (outside diameter?) and whats the widest we can go front and back?
Thanks
swagfu is offline
Old 03-18-2011, 11:22 PM
BWfVA
BWfVA's Avatar
Get on AM and they will tell you a recomended size for your car for the certain size width and hieght of the tire. You can go bigger and wider but you may have issues
I believe for a set of 18's is 255/45 on the front on 9 inch rims and 275/40 on 10 inch rims atleast that is what it is for my car.
They have pictures of customers cars to compare what the size of tires looks like on the car.
BWfVA is offline
Old 03-18-2011, 11:28 PM
jrockgts197
jrockgts197's Avatar
I have 275/40-18 on 18x9 - 99-04 offset on my car all the way around and I'm lowered with Steeda Ultralites. No rubbing, even on hard turn-in at high speeds.
PS - BW, check out the new VA regional section!
jrockgts197 is offline
Old 03-18-2011, 11:41 PM
amustangrocks
amustangrocks's Avatar
Thanks
i like meaty sidewalls myself. i would have stayed 16" if wider sizes were available, so i went with 17". 255/50-17 on 8" up frt, and 275/50-17 on 9" on rear. now those rears are about 1"taller than stock, which changed the speedo a little( corrected in tune) and knocked my 3.73 down a little too. but they look awesome and ride and handle great. you can use this tire calculator to punch in sizes to compare with the stock height
http://www.discounttire.com/dtcs/infoTireMath.dos
amustangrocks is offline
Old 03-19-2011, 09:15 AM
157dB
Cut & Paste Expert
157dB's Avatar
Rim width and offset is needed for the biggest
baddest tire that will fit properly.
I run 275/40-18s on a stock 18x8.5" 50mm offset
and have no problems with rubbing during turning.
But then I also installed the steering stops for 18" rims.
The wider the rim than OEM, the less offset is needed but
the tires start to expand and stick out past the wheel wells.
And then there is the increased load applied to the front spindles
as the tires get a wider contact patch with the road and the
load is placed farther out from the pivot point of the steering.
Wider also gets goofy on the rutted roads and you have to stay
alert to keep it from wandering all over.
157dB is offline
Old 03-19-2011, 09:24 AM
swagfu
swagfu's Avatar
Do you have a picture of your car that shows an entire side shot of it? I would like to see what you have....Thanks for the link to the calculator....pretty cool little tool.
swagfu is offline
Old 03-19-2011, 04:58 PM
amustangrocks
i dont have the option to post pics on here yet, but i have a few pics that i was able to upload in my gallery on here, 1 side shot and a couple others
https://mustangforums.com/forum/memb...6-mustang.html
Old 03-19-2011, 05:44 PM
swagfu
swagfu's Avatar
Dude, that thing is sweet!!!!! I love the bigger tires. I have an 11 so I am hoping it looks good with the meaty ones.
Thanks for the link.
swagfu is offline
NorthAmericanTuning
11-09-2016 11:44 AM
NorthAmericanTuning
03-18-2016 11:21 AM
Gary Ugarek
09-16-2015 08:04 AM
Mr. D
Wheels & Tires
15
08-22-2015 02:58 PM
Quick Reply: Definitive tire size questions
