Iat sensor and oil seperator
Old Feb 22, 2012 | 01:52 AM
Rshustler1's Avatar
Rshustler1
Default update
Just wanted to update, reinstalled oil seperator on correctside... also I noticed quite a bit of oil on the PCv connector
Old Feb 22, 2012 | 03:04 AM
kzonts's Avatar
kzonts
Excellent. Make sure you use the higher strength hose as JimC mentioned. You should catch a spoon full every 400-500 miles.
Old Feb 22, 2012 | 11:01 PM
Rshustler1's Avatar
Rshustler1
I did , jinx and taco bill deserve medals for theirs vast intelligence
Old Mar 2, 2012 | 09:46 PM
zanypunk's Avatar
zanypunk
How many miles on your stang? Sounds to me that you need a PVC. That's the reason why I asked if you cleaned your intake and coated with oil, but you're stating that it's engine oil. Something to keep in mind. :P
Old Mar 3, 2012 | 06:45 PM
Rshustler1's Avatar
Rshustler1
67009 miles inside the pcv tubing was oil but inside the cai. Was air filter oil
Old Mar 3, 2012 | 11:43 PM
tx_zstang's Avatar
tx_zstang
Ah, yes. Over-oiling the air filter is easy to do.
The problem with oil getting through the pcv valve, it gets in the intake, works its way back toward the TB, and cakes up on the egr tube. yuk. A filter on the passenger side works wonders.
jwog666
Dec 27, 2021 08:09 PM
mrtrodonet
Sep 19, 2020 03:12 PM
Dathan
Oct 5, 2015 05:52 AM
wraith777
Sep 28, 2015 10:49 AM
TfcCDR
Sep 14, 2015 12:08 PM
