T-lock
Old Sep 15, 2005 | 02:52 PM
cman332001's Avatar
cman332001
Default T-lock
Did all 2005 v6 mustangs come stock with T-lock.... is this part of the TCS package...in otherwords if u have TCS do u also have t-lock for power to both wheels... can someone please clearify this for me??
thanks in advance
Old Sep 15, 2005 | 03:37 PM
huffhuff's Avatar
huffhuff
Default RE: T-lock
traction lock is an option not standard. traction lock is not the same nor included with traction control system. traction lock is same as limited slip or posi-traction type rear ends. it mechanically transmits energy to the wheel with the most traction in slippery conditions. tracion control applies a brake at the wheel with the least traction and may chop the throttle depending on severity of slippage. they can be ordered together but i am not sure of any advantage to do so.
Old Sep 15, 2005 | 03:39 PM
cman332001's Avatar
cman332001
Default RE: T-lock
thanks I was very confused... other than doing burnouts how can one tell if they have the traction lock option.... is there a tell tall sign to look for? something visual?
Old Sep 15, 2005 | 05:44 PM
Jimp's Avatar
Jimp
I ♥ Acer
Default RE: T-lock
V6s do not have t-lok. None of them.
Old Sep 15, 2005 | 05:48 PM
huffhuff's Avatar
huffhuff
Default RE: T-lock
traction lock is listed as optional in the dealer lit. easiest way to tell is look at rear end cover. traction lock will have a metal tag attached to one of the bolts indicating need for additive for fluid . or get both wheel off the ground, turn one and watch the other traction lock will turn the same direction and non-traction lock will turn the opposite direction.
Old Sep 15, 2005 | 06:02 PM
huffhuff's Avatar
huffhuff
Default RE: T-lock
i'll have to retract the V6 availability of traction lock. i was positive the lit showed both. i don't have it here at work but the option list at Edmunds indicates traction control only available. i hate it and turn it off when i remember to. chopping the trottle is quite bothersome when you want to keep your foot in it.
Matt's 95 Stang
Oct 25, 2007 10:11 PM
DragonPL
May 3, 2007 05:44 PM
cacimar
May 2, 2007 12:33 AM
localgod11
Nov 13, 2006 10:34 PM
tino
Jun 23, 2006 04:56 PM
