35lb fuel injectors on na
Old 05-08-2012, 07:34 PM
Rshustler1
Rshustler1's Avatar
Default 35lb fuel injectors on na
I currently have a Na mustang but do plan on turbocharging within the year but plan on building the kit, I was considering getting started with the fuel system, si my question here is can you run larger fuel injectors on a Na vehicle with a tune? What effects would it have? Where can I find some?
Other turbo items are:
Turbo, boost controller, piping, intercooler, tune. Anything I'm missing?
Rshustler1 is offline
Old 05-08-2012, 07:41 PM
Alec
Alec's Avatar
-turbo
-external wastegate
-boost controller w/ a gated valve
-spark plugs -usually 1 step colder
-hot side piping -usually alum and tig welded
-39 lb injectors of under 350hp if over 55 lb injectors and a KB BAP along with some internals
-vacuum lines
-intercooler
-catch can would be a good idea
-tune
should be everything
I'd wait to have the injectors installed with the kit, dont see a point to have em installed beforehand
Alec is offline
Old 05-08-2012, 07:48 PM
Rshustler1
Rshustler1's Avatar
How do I get 1 step colder plugs? And what is Kb nap, and do you know where I couldfind the hotside pipe?
Old 05-08-2012, 08:07 PM
Rshustler1
Rshustler1's Avatar
Also I plan on staying under 350hp especially unrolling replace the 7.5
GimpyHSHS
19
12-19-2023 01:12 PM
4cylinderplus2
10-09-2020 07:45 PM
Sixx
10-05-2015 07:36 PM
svfetter
10-05-2015 11:39 AM
mrappe
09-26-2015 10:16 AM
Quick Reply: 35lb fuel injectors on na
