13.2 rotor swap on 08 v6
#21
I put 13.2" rotors calipers and pads on my V6 from roush as well. Install was very easy and I saw a slight increase in braking power. I did not see any problems with the length of the brake lines in my car, I did not have to change anything. It is very easy to change the calipers on these cars, I never did a brake job before this and I did it easily. To bleed the brakes all you have to do is buy a brake bleeder kit from the auto parts store and have someone pump the brakes a few times. There is a valve on the back of the caliper covered with a little rubber boot you just have to connect a rubber line to and open while someone presses the brakes. I painted my calipers black, and put a few coats of clear coat on them so they stay nice and glossy. I also took the time to paint my rotors black on the hub part and the the edges so they don't corrode. Very happy with them.
#22
#23
Or did they just look OK where your front tires were sitting/turned to?
#24
I made sure they were long enough lock to lock. I also used caliper paint on the rotors. They have been on the car about a month now and have worked great, there is no peeling or cracking of the paint on the rotors at all. I used a wheel clear coat on the calipers.
Matt's 95 Stang
10-05-2015 07:16 AM
