My Mustang 2006 ABS PUMP Problem.. :(
Old 11-03-2013, 09:04 PM
panama_mustang
panama_mustang's Avatar
Unhappy My Mustang 2006 ABS PUMP Problem.. :(
hello forum friends
I'm new to Mustang
not speak English and use a translator
good start
I am from Panama recently I bought a ford mustang on page COPART as my first car without knowing he had hurt PUMP ABS system the code is
6R33-2C353-AB and I looked on Ebay and do not seem to find that part I've found is 4r33-2c353-ag
what I would like to know if the 6R33-2C353-AB not find it on ebay that I can adapt?
thanks for all ...
Greetings from Panama
File Type: jpg
panama_mustang is offline
Old 11-14-2013, 07:58 AM
flyhigh@mach1
flyhigh@mach1's Avatar
Looks like a good repair job on the front end. I do not know if the ABS pump will fit your car. Brakes are very important, so order the EXACT part for your brakes. Hasta luego!
flyhigh@mach1 is offline
Old 11-14-2013, 08:37 PM
kc5mhb
kc5mhb's Avatar
Look for 2C353-AB instead of the full part number and it may be more useful than the full number. I did a quick search and found several sites that claimed to sell that part.
kc5mhb is offline
Old 11-30-2013, 10:13 AM
157dB
Cut & Paste Expert
157dB's Avatar
The 4 #s that come first are year codes.
The letters after are revision levels.
The 5 digits in between the dashes are
the actual part # you need despite the
first 4 and last 2 numbers/letters.
XXXX-2C353-XX is for 05-09 and should
fit just fine. The module configuration process
is going to be the big problem.
The dealer is going to be needed for this process.
157dB is offline
eastexsteve
3.7L V6 Technical Discussions
12-04-2015 05:41 AM
MonsterBilly
09-19-2015 08:50 PM
drumhedd2005
08-13-2015 09:59 AM
daytooday
08-11-2015 09:22 AM
89blueslug
08-10-2015 07:20 AM
Quick Reply: My Mustang 2006 ABS PUMP Problem.. :(
