2007 Mustang stock Alternator how many AMPS?
I have a 07 v6 without the shaker or fog lights, basic 4 speaker stereo. What is the AMPs of a stock Alternator? Im adding sub/amp but i went with a mono and gonna run a simple 1 sub setup. The amps product page recommenda a 75a Altenator. What amps are these stock alternators? Thanks
https://www.rockfordfosgate.com/prod...tails/r500x1d/
Also any tips on where to route a power wire on the s197's? Any easy to use grammets?
rockauto is showing all alternators as 135 amp so you should be fine. there is a grommet just below the battery on the pass side that has a "nipple" you can cut off and run your power wire thru. compartment side is just above the carpet pass side. take off the pass side fender liner to get access. you shouldn't need to remove the battery. run the power wire under the pass side door sill (if it hasn't been pulled up yet it might stick a bit but will come up) then under rear seat to trunk area. use same routing for amp turn on wire, run rca cables down drivers side. youll probably end up with a lot of ground noise so get an isolator for the rca cable. good luck
digger88
12-08-2009 07:11 PM
