Check engine light is on
Old Jan 27, 2021 | 03:23 PM
Kim Phillips's Avatar
Kim Phillips
Default Check engine light is on
Code 1074, 1075 reading in 2007 Mustang Gt
gas tank won't fill up stops at 1/2 tank any advice.
Old Jan 27, 2021 | 07:30 PM
Derf00's Avatar
Derf00
Gentleman's Relish
Double check those codes. Did you mean p0175 and p0174?
Look up s197 gas tank TSB 07-21-12
Old Jan 27, 2021 | 07:47 PM
Kim Phillips
Default Code
P0174 was the code
Old Jan 28, 2021 | 12:30 PM
Derf00's Avatar
Derf00
Gentleman's Relish
lean code. You have a intake leak or exhaust leak. Exhaust leaks are easy, you sound like a machine gun when idling or revving the engine. Intake leaks are harder to trace. You'll need to start with the intake tube to the throttle body and check to see everything is tight...and/or do a smoke test to see if any leaks are apparent.
foxbod90
Aug 20, 2009 01:30 PM
moosestang
Apr 19, 2008 04:05 PM
ohsevensixiron
Dec 22, 2007 12:50 AM
CrazyHorse0217
Feb 4, 2007 09:39 AM
Big McLargeHuge
Jul 18, 2006 01:59 PM
