2007 Driver side window sagging on front end...
My drivers side window is having a problem where it goes up perfect on the back and is kinda sagging in the front. This isn't the common issue with just needing to be reset or anything as the rear goes all the way up just fine when the door is closed. It functions fine and goes up and seals fine on the rear end of the window, but the front near the side view mirror sags a little and barely seals, and I can hear air coming in down the road and im sure its letting water in when it rains hard. Looks like the front needs to be aligned a little higher. I was just wondering Is there a easy way to adjust the max height of the window in the front side? Ive read some of these windows have adjustment screws? Any help would be greatly appreciated! Thanks!
