Key programming not working
Old Feb 6, 2024 | 06:09 PM
Fabio Zecchel's Avatar
Fabio Zecchel
Default Key programming not working
Hello to everyone!
i'm having a big problem here..the car won't start because my PATS system is activated and the PATS icon flashes rapidly when i crank her; The ECU keep storing only 1 key every time i do the erase and reprogram keys procedure.
When i use Forscan or IDS to do the procedure,they both tells me that everything went fine,and the car start right away with the last key coded;but IF right after i turn her off OR if i take the key out of the ignition without starting her up, if then i try to turn the car ON,the PATS light flashes rapidly when i turn the key in the ON position and she doesn't start anymore. And If i go to check the key count in the ECU, this shows that only 1 key is remained memorized. I've got DTC's B1213 and B1601.
All this happened right after i swapped my ECU with another one i've got at home,to load a tune in it and keep it as a backup. Right after i did the swap, tried to turn on the car, PATS light started to flash and the car won't start. I literally only detached and re-attached 3 connectors in the ecu,and nothing else.
I've got 5 keys,4 of these are Ford OEM and 1 is aftermarket; all the keys were memorized in both the ECUs, and none got to start the car.
So,What could be that is preventing the keys from be memorized in the ECU?it could be possible that some module(SJB)/receiver is failing?Or maybe some wire/connector issue?
P.s. An electrician did a test to the transceiver,and told me that it reads the code stored in the key correctly,so it should work.
If someone could give me an hint on what to check,would be really really appreciated. i'm at a dead spot right now..
dadmac
Jan 3, 2022 06:49 PM
Angel Vanegas
Mar 16, 2021 09:02 AM
Mach1BBFun
Apr 17, 2019 08:33 AM
djfrenzy1973
May 28, 2007 11:11 AM
Crsytal Ice
Jul 27, 2006 03:09 AM
