x-cal2 help
Old Dec 16, 2005 | 08:23 PM
onefastv6's Avatar
onefastv6
Default RE: x-cal2 help
thanks guys,
if you the tune on your x-cal and you pulg it in will automaticly be in your cars computer?
Old Dec 16, 2005 | 08:52 PM
NewMexMustang's Avatar
NewMexMustang
ORIGINAL: RedAlertlb
ORIGINAL: LesteR723
ORIGINAL: onefastv6
and my second thing is with a 91 octane tune what should my 0-60 mph be?
i'm not too sure that bumping up your octane would shave too much time off your 0-60...
just my .02
raising the octance is sapposed to give the car alittle but of hp and tq but not much you might take off like 0.05 secs off
it's not "just" using a higher octane...it's not the octane that's giving you more power its the increase in valve timing. You need a fuel that can be compressed more before detonation, that's the only reason to use 91-93.
Old Dec 17, 2005 | 12:22 AM
Torch_Vert's Avatar
Torch_Vert
You can't adjust the valve timing electronically on the 4.0 (that's mechanical), A higher octane will allow a tuner to advance the ignition timing though, which will boost performance.
Old Dec 17, 2005 | 04:29 AM
Pyrat's Avatar
Pyrat
ORIGINAL: onefastv6
thanks guys,
Not quite sure I understand the question, but initially when you plug in your XCal2, it will download the stock tune. You must then select one of the three provided tunes, 87, 91 or 93 octane, so if I understand correctly, no it will not automatically load the tune to your cars computer.
Old Dec 21, 2005 | 11:02 PM
onefastv6's Avatar
onefastv6
sorry i typed it wrong
sp44
May 14, 2008 11:54 AM
opticalveracity
Mar 4, 2008 02:45 PM
Stang4105
Oct 14, 2005 12:04 AM
