C&L Intake and SCT Tune Question?
RE: C&L Intake and SCT Tune Question?
ORIGINAL: bztz4m
I have a question when you did your dyno pull which gear did they do it in. When they did mine they did the pull in 2nd Gear.
Dynos are normally done in 4th gear where the ratio is 1:1.... Doing the dyno in 2nd would explain the low numbers... just like when you change the ring and pinion you can shift your HP numbers lower...
That is what I thought since I was looking at the C&L web site when they did their Dyno run in 3rd with overdrive off. But anyway I only gained 7hp I was hoping for more like 15. But the car does respond better. Thanks for your help on this question.
Calizic
08-28-2015 01:46 PM
inyadreems
08-21-2015 09:10 AM
