Sequential Turn Signals
Old Jan 6, 2006 | 04:20 AM
lmmmmm's Avatar
lmmmmm
Default Sequential Turn Signals
Can you put these on an 06 V6?
If so, where can you get them.
Old Jan 6, 2006 | 11:23 AM
bztz4m's Avatar
bztz4m
Default RE: Sequential Turn Signals
I have them on my '05 so you should be able to put them on your '06. The ones I got came from CDC (Classic Design Concepts) I think they about 149.00.
Old Jan 6, 2006 | 01:23 PM
05 Cayuse's Avatar
05 Cayuse
I also got mine For my V6 from CDC, $149, and they were a snap to install. Especially for us mechancially challeged guys. Go for it, and you'll love em!
Old Jan 6, 2006 | 02:21 PM
burdweiser's Avatar
burdweiser
I got mine on ebay for @ $40. The tail lights should be the same for the 06's. If you want to make sure, pull one of your tail lights out and check the inside light socket, if there is an open socket you should be good to go. When you look at the attached picture, it will be where the yellow wire goes.
Old Jan 6, 2006 | 06:16 PM
karlriggs's Avatar
karlriggs
Yup, I got them for my V6 also, Look amazing, I bought the kit from Meter4it, simple easy, no messing around for "which wire goes where". There is another thread similar to this one, since there is no difference in tailights between the GT and V6 the threads are basically the same.
Meter4it Tailight Kit Thread
Old Jan 7, 2006 | 09:56 PM
scheetz83's Avatar
scheetz83
i also have the Meter4it kit. It was reallt ez to install, i think it took 30mins. I went with that kit because in adition to the sequential setting there is also a Chase setting(that is what i use)
http://www.meter4it.com/2005_Mustang.htm
check out the videos on there site
Old Jan 7, 2006 | 10:29 PM
lmmmmm's Avatar
lmmmmm
I read the Meter4it site but I dont really want to run wires all the way to the battery.
Is there a simpler kit to install?
Old Jan 7, 2006 | 11:33 PM
scheetz83's Avatar
scheetz83
i am not 4 sure but i would think that you would need a power wire from the BATT with any kit out there.
As far as running the wire it is really easy just poke a hole in that boot on the fire wall pass a wire throught into the cab and just tuck it in under the door trim, you dont even need to remove it. The only thing you will need to remove is the back seat which is really EZ.
hope this helps
Old Jan 9, 2006 | 12:48 AM
doctordrv's Avatar
doctordrv
Yes you can I put them on my V6
Easy to install I got them from
http://www.mustangtuning.com/
Dave
jwog666
Dec 27, 2021 08:09 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
breaking
Oct 2, 2015 01:27 PM
Sep 30, 2015 12:39 PM
logan409
Sep 26, 2015 07:43 PM
