Remote wire....?
Old Jan 13, 2006 | 03:10 PM
RedAlertlb's Avatar
RedAlertlb
Default Remote wire....?
does anyone know where i can connect my remote wire with the factory headunit still in.
Old Jan 13, 2006 | 04:07 PM
RedAlertlb's Avatar
RedAlertlb
Default RE: Remote wire....?
somebody has to know where i can connect a amp remote wire
Old Jan 13, 2006 | 04:12 PM
prozac's Avatar
prozac
u can splice it into the factory connector if ur hellbent on it, but ur not going to get vey good output from ur factory unit most likely
Zach
Old Jan 13, 2006 | 05:03 PM
RedAlertlb's Avatar
RedAlertlb
i have tried that it couldnt find the right wire to connect.....so i guess im back to 1
Old Jan 13, 2006 | 06:52 PM
prozac's Avatar
prozac
u can hook into the red wire if u need to, thats ur ignition, that is how mine is hooked up, works the same
Zach
Old Jan 13, 2006 | 07:32 PM
RedAlertlb's Avatar
RedAlertlb
the red wire behind the HU?
Old Jan 13, 2006 | 08:16 PM
RedAlertlb's Avatar
RedAlertlb
i tapped into a wire in the ignition harness its black and pink...works wonders. if anyone else need this asistance its on the lefts side of the steering wheel underneth
Old Jan 13, 2006 | 08:35 PM
prozac's Avatar
prozac
good job, it sounds like you tapped into the battery 12 volt constant wire, wit should be great, but just make sure your amp turns off when you turn off your car, one more thing, what did you hook your RCA's up to???
Zach
Old Jan 13, 2006 | 11:54 PM
scheetz83's Avatar
scheetz83
hi
i taped in to one of the mini fuses in the underhood fuse box on the passanger side
Old Jan 14, 2006 | 01:35 AM
RedAlertlb's Avatar
RedAlertlb
ORIGINAL: prozac
Zach
I brought a signal converter rca's on one side and speaker wire on the other side....
I didnt tap into the 12volt constant it is the accessory wire.
movielover40
Aug 27, 2015 10:13 PM
97Cobra
Nov 17, 2006 10:01 AM
sykopafikjuggla
Jan 20, 2005 03:47 PM
Steve88XJ
Sep 30, 2004 08:54 AM
98LS1
Aug 1, 2004 08:10 PM
