18x9 +36 wheels on a 2003 mustang will thay work?
Old Mar 4, 2008 | 10:48 PM
gjs14's Avatar
gjs14
Default 18x9 +36 wheels on a 2003 mustang will thay work?
I need to know if my wheels will work on my moms 2003 mustang gt
wheel size is 18x9 +36 offset
hear are the wheels 18x9 Euromax 612
Old Mar 5, 2008 | 01:09 AM
dmh@bones's Avatar
dmh@bones
Default RE: 18x9 +36 wheels on a 2003 mustang will thay work?
they will but you will need a 1/2" spacer and some ET style lugs. The offset on that rim is about 10mm higher than it should be. it will bolt on just fine but when you go to turn lock to lock you will hit the sway bar in the front. the rear will be close too. We keep the ET lugs and high quality and the cheap spacers in stock because we do sooo many mustangs here at the shop. You can do the cheap spacers and ET lugs for about $50 or so and the high quality ones for about $150. The cheap ones will work but you run the risk of having some vibration issues. if you wanna gimme a ring i can explain to you how to put on the cheap ones to minimize your chance of vibration and try to save you a few $$$.
Old Mar 5, 2008 | 11:05 AM
gjs14's Avatar
gjs14
thanks and yes I will give you a call, how safe are the spacers? will the stock studs work with the spacer?
Old Mar 10, 2008 | 12:30 PM
dmh@bones's Avatar
dmh@bones
Thanks
daytooday
May 2, 2018 05:56 PM
'stangdude
Aug 12, 2015 01:27 PM
ccwebb
Aug 11, 2015 06:47 PM
daytooday
Aug 11, 2015 09:22 AM
Mr. D
Wheels & Tires
Aug 8, 2015 05:43 AM
